Hey guys i was under my bike today and noticed some random green grease right below my shifter and trans is this normal? also i have not been having smooth up shifts i ignored it for awhile now but it doesn't feel right, hard to explain but its not as smooth as when you down shift it feels like it catches or doesn't go into gear right away 1 N and 2 feel fine just going past that.
couple drops of coolant mixed with grease and road grime maybe?
Can you take a picture from further back, so we can see more than just the bolt and greasy area?
I'm thinking that is coolant, and its coming from the coolant drain bolt or the water pump itself.
BOTM Winner 07/16
lube the knuckle joints of the shift linkage and any moving parts on the rearset that has anything to do with the shift linkage.
Are you running OEM rearset or aftermarket?
Often Aftermarket doesn't have a closed bearing and need regular lubing on the moving parts otherwise that may not move as freely as it should be.
