1 - 11 of 11 Posts
I just recieved the LEDs the other day and tried to install them but they want work. I have tried ever wire ever way possible still no light. If any one has these lights could you give me a tip on the install? Thanks in Advance!
I have tried the wires in ever way possible. I tested to find + and - and switched both ways still no light. I ant not rocket scientist by no means but do know my wiring cant get nothing to come on.
Check your fuse's,
if your fuse is ok.
try connecting the + and - wire to a 9v or any battery to test to turn signal
To see if it lights up.
if it does. its your wiring skills ;-) .
H
did you get the extra harness piece that allows you to have running lights...
if you had your battery connected while doing the wiring, and it was wrong, you might have blown a fuse. Id check that first.
1 - 11 of 11 Posts
