Ok I haven't been on here in forever, that being I said I need some help, My bike has been sitting in my garage for a couple of months maybe like 4, tried to start it battery dead, went to the dealer and got a new battery, 4 qts of oil and an oem oil filter as well as some coolant and motul chain lube, went back, did the oil change, lubed the chain and put in the new battery started right up and ran good with no problem but is there anything else I should change or do maybe replace and bleed the brake/fluid and do I might need sparkplugs ? I've got an 08 with 6,700 miles on it...
You do not need any spark plugs what the bike needs is a decent 100 miles ride
to get the fluids flowing all over the bike that will make her happy and will put
a huge smile on your face for sure
sounds like you have it covered...maybe check the tires for air pressure / flat spots?
As others have said, time to ride! Nothing like a good long ride to clean the plugs and strech her legs a little bit.
