1 - 9 of 9 Posts
While i wait for new frame shims i'm tidying up loose ends, ordering bits and pieces etc.
At the battery there is a single wire that comes off the positive battery terminal with a plastic female plug about 3" from the terminal, can anyone tell me what it plugs in to?
Cheers
Paul.
Mine is a 2007, you can see in the pic it's attached to the + terminal, it has a wire with a red terminal in it which the PO used for a power supply to a fan.
that connector feeds fuses E (clock), F (fan motor), and G (EFI) in the fuse box with constant power.
it's pretty important to have it connected... lol
That's interesting, the HRC loom is a bit different then, like i said the PO used it as a fan supply which he rigged up as a manual on/off using the horn switch.
The HRC manual tells me to snip it off, just wanted to see if i'm missing anything before i do.
Might leave it intact until i've got it completely reassembled and confirmed it starts!
you never specified that this was an hrc harness. i can't comment on what it should be plugged in to as i don't have a drawing for that harness.
Yes, i know. Like i said, i know what it does in the HRC harness (Nothing) i want to know what it does in a std road bike.
Thanks.
1 - 9 of 9 Posts
