It's a BAS (bank angle sensor) or commonly called tip over sensor. It shuts the bike down when you lay it over. Can also be easily bipassed
that piece should NOT be where you are holding it. it should sit between the headlights.
it looks like the tabs for attaching it there are broken.
was your bike rebuilt after a crash? there's certainly something fishy going on there.
Yes, you need your BAS if you are ever going to run Bazzaz Zfi-TC...Second, it needs to be mounted up front on the upper stay. If you hear something rattling then something is broken. Just replace the BAS...Order a mount.
