1 - 9 of 9 Posts
i can't seem to find this part. its a rubber grommet that you screw into. its on both sides that hold the side and lower fairing together. i circled the screw that goes into the rubber grommet, but don't see the grommet listed.
^^ this is where it should be, but mine fell through the hole since they are cracked.
NO, it is not "just a gromet" its a well nut. and is what the fairing bolts screw into
part 15 i belive.
Reactions: blurider
As tenjin said, its a well nut... also know as a speed nut.
I confirm that it's a well nut, just go to your local bike shop and pick some up. Grab a few because they will always fall apart.
good call!!
my local dealer doesn stock anything, so when i went to order a couple bolts, i ended up ordering a plethora of different thing like those and different body bolts.
1 - 9 of 9 Posts
