1 - 11 of 11 Posts
I am looking into purchasing a used 2008 600rr this weekend from a local seller. Bike has 3200 miles on it, oil has been changed at 500 miles & 1500 miles and tire conditions are good. Seller admitted that the bike has been down once on a corner at about 15mph. Images shows 2 minor scratches that is not very noticeable. He also mentioned that he took it to the dealership to get it inspected after the accident and the results came out negative, however he doesn't have the paperwork to back this up.
Is there anything else I should be concern about or questions to ask before purchase? Thanks in advance for any buying tips.
check the engice/clutch casings for marks, the foot pegs/pillion pegs from scratches/scrapes etc
bar ends/levers for damage if they are bent etc
Mirrors scrape marks on them..
Really try and find as many scratches as possible and then state well its $50 to replace the mirrors, bar ends $20 etc etc
As buying a damaged bike comes with worries, Ask if he has changed the air filter, has he the original books? receipts of oil change?
ask about the service by dealer or self done? receipts? look under teh rear tail for the chunks of rubber from burnouts- they can be scrubbed off but take some muscle. that will help tell if he abused the bike or if hes just that anal about seeling and didn't want to miss teh abuse.
Go read this...
http://www.clarity.net/~adam/buying-bike.html
And let the words of the Gospel itself lead you to a fit new ride.
Nice link, thanks!
Further to checking the VIN, make sure it has a clean title (not salvage, non-repairable, or stolen) and do a lien seach to make sure there is no money owing on the bike, because you can unintentionally assume the loan on the bike.
checklist
Below is a basic list that I got from somewhere on the web.
I've used it several times when looking at used bikes to buy. I put it in a spreadsheet, print it out and just check the items off as I'm inspecting. Feel free to use it, modify it for your own purposes.
I find that it keeps me on track and makes sure I don't take short-cuts or get caught up in how great a bike looks or sounds.
Again, its a basic list but its served me well. Good luck.
MC Inspection Checklist
1. Obvious different paint work that may have been done to cover up damage, or stickers trying to hide damage
2. Bent or replaced levers, mirrors or forks and dents that may indicate that the bike has been crashed.
3. Any misaligned panels.
4. Do the tires have reasonable tread left and are there any signs (wear in the center of the tire) of tire spin
5. Check for holes or rust in the exhaust
6. Can the gas cap be locked with the motorcycle key and are there any signs of rust inside the tank
7. Is the upholstery in good condition and does that lock work with the motorcycle key
8. Does the front and back suspension move smoothly and quietly when pressing down and releasing
9. Is the chain in good condition, is the tension correct and are the sprocket teeth not bent or worn
10. Is there tension in the front brakes and do they work properly when tested on a rolling bike (same with rear brake)
11. Do the wheels have dents
12. White deposits on motorcycle batteries are not a good sign
13. Check the oil color through the sight glass or use a dip stick to see if it was recently changed
14. Check the coolant color ‐ bright green is normal and may confirm that the motorcycle was not used for racing
15. Does the motorcycle battery start the engine easily from cold and does it run smoothly
16. Is the oil pressure light working properly
17. Test the headlights, indicators, neutral light, horn and brake light
18. Is the side stand cut‐off working
19. Does the kill‐switch on the handgrip work
20. Are any fluids leaking from the engine
21. Confirm the odometer is working properly by riding or have the seller ride it and enter the reading on the motorcycle bill of sale
22. Check VIN on bike vs paperwork
Nice link, thanks!
How can I do a lien search on the bike?
1 - 11 of 11 Posts
