1 - 9 of 9 Posts
So my bike came with this fender eliminator/license plate bracket with a tiny ass LED strip, and I wanted more visibility so I bought a Tripage IT off someone on this forum.
But it doesnt look like the photos of other people's Tripage IT's. There arent any mounting brackets and stuff.
So whoever installed that fender eliminator thing snipped off the wiring clips and I just have the wire ends. I am trying to figure out what color corresponds to which wire on this integrated tail. I thought I wired it up right but cant get the Tripage IT to light up or blink etc.
I need to fill in these blanks of what these wires correspond to:
Tripage IT:
three prong connector:
red
black
white
two prong connector (left signal):
white
black (not connected)
other two prong connector (right signal):
white
wires on bike:
green wire with yellow stripe
green wire with gray dot
white wire with black stripe
green wire
orange wire
green wire
blue wire
driving me crazy!!! why wont it light up?! why did they have to cut off the stock connectors?!
red Ground
black Running
white Brake
white Orange wire
black (not connected) Not needed
white Blue wire
wires on bike:
green wire with yellow stripe Not sure if this is brake or running
green wire with gray dot GROUND
white wire with black stripe If this isn't the running then it's the brake
green wire
orange wire Left white wire
green wire
blue wire right white wire
Thanks for the reply tripage.
Will the tail light not light up without all of the wires connected properly or should it light up with just the red/black/white?
Also, is this an older tripage IT? I'm wondering what differences are there in how it mounts.
Light will only turn on if the ground and running light are attached..
Inside is the only difference between new and old IT boards.. If you take the left and right white wires and power them both at the same time and both signals turn on then it is the new board or has been upgraded to the new components.. If only one signal turns on it's one of the first run boards. T
Thanks for the help Tripage-- the running and brake now lights up just fine.
The signals won't work though-- when I connect the blue and orange wire to each of the white wires respectively, the yellow LED's come on and stay on solid regardless if I signal or not. The blinker choice button won't do anything either.
Damn, almost!! I posted a picture of the problem. You can see the wires connected properly but no dice on the signals.
Sounds like you have led signals up front or no signals up front. If the signals are turning on and not flashing you don't have enough resistance and need resistors or a flasher relay to return this rate to normal.
Make sure the signal is off before hitting the button without the red dot, this will change the flash pattern.
Flasher relay install:
Hey Tripage, What relay is that? (In the Video)Do you offer one of those? If you do, is there one for the for the 05-06 600rr?
1 - 9 of 9 Posts
