So of course no two bikes are the same, and without a custom map...you may not be getting all that power you could attain.
I have a Jardine slip, stock filter...and run the map (jardine slip, stock or aftermarket filter). On the PC3 itself, I keep the low med and high settings all at the 0 mark.
What about you guys? Have you ever adjusted the low med and high on the PC3? If so would you mind sharing what you put them at?
Thanks
Thanks
