So was getting my subframe put back on and ran into a bit of a pickle. I have these two bolts still left and not sure where they go. The return spring is back on the bike now.
As well as these two little rubber guys. I know they go somewhere on the subframe, but can't remember where; is it going to hurt anything if I leave them off?
The short allen bolt looks like a fairing bolt, did you bolt the tail fairing with 4 bolts under the pass seat? Looks like one of those bolts...
The small bolt goes at the front of the under tray. It connects the tray to the cross member on the subframe
Thanks Wibbly.
CBR247, none of those are fairing bolts. Fairing bolts are all bagged up still.
The rear Cowl has 4 bolt points right inder the rear seat (or seat cover).. I remember two of the being large allen bolts, and the rest are samller, check if you have the four of them installed...
I can almost assure you that bolt belongs to some part of the fairing...
