i have an 09 600rr and sometimes it wont start. I can push start it and next time it starts right up so I dont think its the battery. Seems like it may be losing ground? Wired are tight on the battery. Where does the ground wire connect to the chassis on these? I'm assuming one wire goes to the starter and the other to the frame but I can't seem to locate it.
I hate to sound dumb but I have the fairings off and I can't see the starter anywhere. I assume the end with the ground is on the right side but its hiddenbehind something?
Starter is beneath the gas tank...and the throttle bodies. If you look in from the left side of the bike...look just above the top of the two hoses than run up from the bottom....near the shifter rod going into the case.....
