Done a bit of a search and still cant find it. Im pretty good with this stuff generally, but just got the bike and dont know anything about whats where yet.
2007 Australian bike with hazards- 4-pin relay.
Replaced both front and rear with LED indicators. Flashing fast.
Bought this relay:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=271428369932
Not sure where to start looking for the relay though? I know the battery is under the seat, as well as a bunch of plugs or the fusebox or something :p is it under there somewhere? Would it be labelled so I can pick it easy?
Ive also found a few threads for 2006 models saying their relay is in the cluster, so they had to cut some wires to bypass it and wire the new relay in somewhere else. Is this the case with the 2007 model as well?
thanks heaps.
will it be labeled in english? or will i easily be able to trace the rear indicator wires back to it to find out which one it is? or is there only one relay there so itll be obvious?
Its going to be very obvious, you will see it right away once you take the seat of and look between the fuse box and the servo motor.
