Sounds silly but i dont know where it is located. Better to sound dumb in here than f up the bike...
Doing first oil change
Thanks
Thanks
NewRedRider said:Buy this at your local Advanced Auto or Dealer. Take a new filter with you so you know what size to get...
Read this..
http://www.600rr.net/vb/showthread.php?t=30967
And then get someone to help you hold the bike upright the first time. You need to check the oil level after you warm the bike, shut if off, and then let is sit for a few minutes. Then check the oil with both tires on the ground. You can't use a stand.
I know you just didn't say that...KhMeRGuY978 said:don't forget to use motorcycle oil...![]()
Do you really think you're getting off that easy?!E.10 rider said:Alright alright....... I was at a buddies house did not have my manual and did not know where to look... i had already done the oil change. everything went smooth she is good now. I had a blast down at the track this weekend had a spill but just some rashed fairings, a broke break lever, bar end, and some messed up leathers thanks for all the help... will post up again hopefully next time will be some more substantial
