Hi guys ,
Need some help please.
I'm trying to set the voltage to within the factory spec range using a multimeter. However I don't know which two wires to connect to positive and negative .
I've got a spare TPS OEM wire which I will connect to the harness as seen below to test
Cheers
Nitin
White Plant Gesture Yellow Finger
Discussion Starter · #4 ·
you have to have the TPS powered to set the voltage, you can't just plug what you've pictured onto it and start measuring for voltage on the wires.
it'll be grey/black and blue/yellow that you're checking for voltage on.
Thank you Mate. Yes I will connect this wire to the wire on the harness and plug in the TPS. Just to clarify the grey and black is the negative and the blue and yellow the positive?
Cheers
Nitin
