1 - 10 of 10 Posts
I'm installing hotbodies LED turn signals in the front. I followed the guide stickied on the top of this page. I"m using a 10W 10 ohm resister in parallel on both sides. When I plug it in, I"m not getting any signals and it's not showing my blinker blinking on the control panel.
"Superman dat hoe"
you need resistors.
Do you have them wired right???? Green is the ground on your bike....
They are wired correctly. I'll post pick. The instrument panels is working, but when the turn signals are on, they don't light up on the instrument panel.
I haven't tested the wires. I soldered all my connections except I did use the plastic no-solder connector to add in the parallel resistor. I uploaded a diagram showing how I wired it. The pink boxes are the resistors, the blue are the solderless concector. my green wires is hooked up to black on both sides, and I'm connecting the red to the solid orange or blue depending on the side. I'm doing nothing with the striped wire. Please check to make sure I have it right.
found out. blown fuse.
1 - 10 of 10 Posts
