Ok, I don't have a way to properly measure this but let me tell you waht I'm doing. My dad is helping me make a rear stand out of square tubing. Can someone who has a spool stand measure the distance between spools. Since the stand is being built from specs I need a fairly accurate number. Thanks in advance guys...
I've Got A Fever
I have Graves swingarm spools and the distance from the middle of one to the other is 14 inches. Your best bet would be to buy the spools before you get the stand built so you know the exact distance. Spools vary in size which will throw your measurements off.
ok, I found a ruler and devised a very mechanical engineering way to measure them. My spools it appears are 13 5/8" center to center.
