Actually there is an advantage to running the 05 shock. The preload adjustment has a greater range (1-10 vs 1-7) which allows for a more precise setting to match the riders weight or preference. I have an 05 shock that I'm looking to swap with mine and everything I can see tells me they will swap.ryoung57 said:Should fit, the penske I bought was on an 05 and it fits fine. Only do it if yours is shot. There won't be any performance gain.
That a cool deal. Just too bad I've already got a Penske 8987 for my race bikeNewRedRider said:Actually there is an advantage to running the 05 shock. The preload adjustment has a greater range (1-10 vs 1-7) which allows for a more precise setting to match the riders weight or preference. I have an 05 shock that I'm looking to swap with mine and everything I can see tells me they will swap.
But before you do that have you seen this?
http://www.tracksideengineering.com//ecommerce/catalog_ms2.2/product_info.php/products_id/23?osCsid=9ab49f65be72e9b27051ddc3796d07bf
