1 - 8 of 8 Posts
It's basically the exact same engine, yes it will bolt right in.
Discussion Starter · #6 ·
maskale said:
You may want to change your ECU also, the ports are different, so your fuel requirments will be different, although a PC and a custom map may solve that for you.
what about the wiring harness? if i use the 05 ecu can i still use the 03 harness? just wondering
1 - 8 of 8 Posts
