1 - 12 of 12 Posts
Hi colleagues.
I hope someone of you may give me an idea what is the problem with my bike. It is the 2004 Honda CBR 600 RR and the issue is the following: let’s say I am riding with 150 km/h and then I brake, when the speed decrease to 95 km/h the windshield starts to wobble, then at 75 it stops and starts again when speed is 40, and it stops again in 25 and is missing till 0. The trebling is very fast and it is only on the windshield, the range of moving is about 2-3 centimeters, up and down. The levers and the handlebars are not shaking at all, I don’t see it and I don’t feel it on my hands and fingers. The problem started in 2017 and I am not sure why it started. My tires are new, front is 0617 with 4*000 km on it, pads are new, I’ve changed the bearings on the steering wheel (no slacks on it), the bearings on the front wheel, I’ve serviced the forks, the suspension settings are standard, I’ve been riding with 3 different pairs of front discs (not new ones) and it does the same wobbling with each of them. The braking calipers are serviced and there is no leakage, nor signs of damage. Both rims have small curves (1 on the front and 1 on the rear) but when riding even 180+ km/h there is no problem, no shaking.
Any idea what may cause this wobble ?
Did you by any chance add something that changed the aerodynamics of your bike when this started happening? Tailbag, saddlebags, different plastics, etc? It sounds like your going in and out of the natural frequency of the part. Is it OEM? if it's OEM, look for loose fasteners. If no loose fasteners, or it's an aftermarket windscreen, do a test to find out if it's a resonance at the natural frequency; get some non residue tape and apply it along the edges of the windscreen to attach it to the fairing, this will change the natural frequency of the part. If the resonance goes away, then it's the effect of the natural frequency of the windscreen. You could maybe add some sort of a dampener (washers) to a couple of the fasteners. As a alternative test, you could just get the resonance going, then put your fingers on the windscreen to see if that makes it go away. If it does, then same thing, it's the effect of the natural frequency of the windscreen. Add something like washers (so they're in contact with the windscreen) under the fasteners to change the natural frequency of the windscreen. If the resonance doesn't stop when you add tape, put your fingers on it, or add dampening washers, idk. Good luck.
Nothing added. No bags or such. I added crash pads, but they are tightened well and I don't think this can be the reason. Also balancers on the handlebars but they should help, not cause problems! The windshield is aftermarket double bubble but at the very beginning when I bought the bike there was no problem with it. I may try to change something on the fasteners of the windshield or try another one or remove it for test. But I still wonder what may cause this. The windshield is part of the front fairing, it is caught for the frame of the bike and my logic is that for some reason the body is shaking. I first thought it is a mechanical problem and that's why I changed all bearings and spent all these money. But honestly this bothers me every day. Thank you for your suggestions !
The windshield nuts are new, I tightened them as much as possible. Also I have changed 3 different types. Now I put washers on the mirrors but no charge. I folded the mirrors in order to change airflow on the bike - no change. Removed the balancers on the handlebars but nothing. When touching the windshield the treble stops. I will replace the crash pads with the original bolts to see if any change. Also I will remove the plates that cover the brake pads and try with low speed to see the behaviour. (Know this is risky !) Keep thinking it's something on the calipers but it should be something really tricky to find. Maybe something like not a smooth work of the cylinders, but I don't feel a push back on the brake lever. ?
Just to share the reason for my problem. It was the crash pads, their bolts.... . The hint for the resonance was helpful. Thanks! Today I tried to tighten them and the bolts made 1-2 turns until they were tight enough. I made a test ride and there was no wobble. I love my bike again ?
What "crash pads"? Frame sliders? So the upper engine mount bolts? If yes, they should be TORQUED to 40 lb-ft. Not just tightened.
Glad you found it.
Discussion Starter #11
Yes. Frame sliders. I don't have such wrench so I just tightened them as much as I could. The good is that I found the reason. Next season I may torque them to the specified value. This problem was tearing my nerves every day for the last two years. I never thought this could be the reason. A big load is now off my back :))) I changed steering bearings and front wheel bearings and braking disks...but just had to tighten 2 bolts instead. Mad story!
You should get a torque wrench. I have (3), 1/4", 3/8", and 1/2" drive. They aren't cheap, so I'd start with the 3/8" drive size as it will cover most of your torque requirements. You may have tightened them the 1st time, but if they weren't torqued enough, they can loosen up. The other scenario is similar, if you overtighten them, the bolt can yield, and then it can loosen up because the bolt material has yielded. In this case, you would need a new bolt. There are torque requirements for all bolts, but some bolts are critical. If it's critical, it's called out in the engine manual, If less than critical, use a standard torque chart to get the value. An engine mount bolt is one of these critical ones, as you have experienced.
1 - 12 of 12 Posts
