1 - 20 of 30 Posts
What mods or maintenance do you have planned for this winter?
Fork rebuild
New 520 chain
Speedodroid or what ever its called
Steel brake line
New pads
New fairings
Frame sliders
Fix headlight switch and kill engine swith (anyone got a link?)
More im sure im forgetting..
BOTM Winner 05/15
On my list of things to do:
-Pull motor and clean the engine.
-Install headers
-Install PC-V and get it tuned.
-Rebuild calipers and new pads
-Rebuild forks with new springs, seals, valves (or cartridges if I can find a deal)
-New bearings in all the pivot points, steering stem, and wheels. Hoping to find a set of ceramic bearings for the wheels, but cost may be prohibitive.
-Track fairings prepped and painted
-New tires
-Finish the swingarm covers that I started last year
Work on my GS550L and get it running, then stripped down and refinished.
repack two bros can (desperately needed)
install Luckybike heavy weighted bar ends
maybe paint subframe black
maybe projectors
gotta keep it cheap, trying to save for a second bike!
fork and shock service
riding
cleaning
- Replace incorrect passenger rear set (previous owner put a set from an 07 on..) with correct powder coated black set.
- Remove all fairing and degrease entire engine and fairings.
- have a shop install vortex chain and sprocket kit I purchased off of a member here. (My own sake I'll leave this to the pros lol.)
- apply white reflective rim tape.
- replace air filter with a K&N.
- Lastly want to replace all plastic clips and possibly install black set of fairing bolts.
BOTM Winner Jan 2015
Already did most of it, but new windscreen and levers, build a passenger peg block off plate, upgraded some of my riding gear, and I finally found a place in town that can dial in my suspension to my weight.
Finally do a proper clear coat on the fairings that won't get eaten by gas and cleaning supplies. Other than that, tires, front rotors, and RIDE!
Absolutely nothing. Bike is exactly where I want it. Already winterized and put away. Only thing I can do now is wait for warm weather.
Nothing. Always warm 28c year-round here. ^_^
The aprilia is getting a brembo caliper conversion with titanium bolts and new brake pads. Waiting on said bolts and brake pads...
Discussion Starter #19
Whats wrong with your rotors? There rarely warped just a heads up
1 - 20 of 30 Posts
