Can somebody do me a huge favour with their 07 inwards CBR please?
On the right hand side of the bike, where the front sub-loom connects to the main loom (the large grey connector block) there is a small single wire connector running alongside it. The wire is pink with a green stripe.
Please could somebody undo this connector, flick on their ignition and give me the voltage reading please between the connectors?
I think it should be in the 12v range, but I may be wrong. Mine is currently showing 2v and is fluctuating. My fuel pump is not priming and the bike will not fire, it just turns over. I have checked pretty much EVERYTHING and this is a reason why it may not be starting correctly.
I had to change the original connector when it failed on me at a trackday, so I temporarily changed it for a cheap bullet connector, I now have a proper motorsports race spec connector to use, but I need to check the voltage is correct before I go ahead and fit it.
Many thanks in advance,
Tom
