1 - 8 of 8 Posts
ok just mounted my sliders on bike! having problem with the large puck on the right side doesnt fit on only the small puck will! ( as for right side i mean throttle side )
help do i need to modify the larger puck base or am i missing something!
ps will post pics in a few the cuts turned out great!
also gonna post some upgrades homemade did them tonight, and is anyone using this lock?
Discussion Starter · #7 ·
I used a 2" hole saw just eyed it up drilled a pilot hole to make sure and then went thru with the hole saw, after that i used a razor blade to cut off excess plastic, finaly i used 220 grit sand paper to finish it off.
This is an older thread, but did you get this figured out? Im about to install mine and when looking at the box, there was a sticker that says "install the larger bolt on the left side". One bolt for the slider is about 1/4" - 1/2" longer than the other. Im sure that may be your problem.
1 - 8 of 8 Posts
