1 - 13 of 13 Posts
I bought a used 07rr couple months ago from someone who had it parked for a while. When i got it, it`d rough idle - it`ll purr , cough , purr cough. (warm or cold)
At first i thought it was because it was parked and there was some stale fuel or something in there , but after 500miles , some injector cleaner in the tank - the idle is still rough. (using 93 octane fuel)
I have no power loss and the bike runs great, save for this idle problem.
Anyone has suggestions for what could be causing this?
btw - Its got a 2 bros slip on, and is otherwise stock.
Tried holding a rag on the exhaust tip - to check for a back pressure issue - still the same.
Try cleaning the throttle bodies. Might just be a little carbon buildup.
My idle got just a little bit rough when I put my Two Bros on.
Just how rough are we talking here though?
if its just an occasional note difference i wouldnt be worried about it.
probly the exhaust messing with the curve enough to change up the sounds
whats it idling at? below 1500rpms? Once mines around 1300 where it says in the manual it should be, it gets kinda rough if it goes just a shade under 1300 so maybe its simply just idling too low? when mines to low it kinda cuts in and out, and reminds me of how a single cyclender quad or something would idle, its really choppy. I have a 06 with two bros slip.
07+ == non adjustable idle
Discussion Starter #8 (Edited)
well its a regular "cough" to start and by rough , there isnt any significant change in rpms, the needle just bobs around the 1300 mark.
As far as i can tell the exhaust valve is still operational so wouldnt that keep the backpressure and AFR in check? btw - there is no O2 sensor on this bike.
It actually does sound like its idling low or is runniing a very rich fuel to air mix - kinda like a dragster , but not as rough or as loud ..lol
short of getting the bike mapped
there is nothing you can do to change it .
good tune may help.powercommander ftw
1 - 13 of 13 Posts
