How To-Front Wheel Removal - Page 3 - 600RR.net
03 / 06 RR This forum is dedicated to all the How to write ups for 03 to 06 RR
post #61 of 83 (permalink) Old 07-18-2010, 06:02 PM
used this writeup and it worked really well for me thanks for the writeup.
iliveintn is offline
post #62 of 83 (permalink) Old 10-21-2010, 12:45 AM
trackscoot22's Avatar
Feedback Score: 28 reviews
For sure is the axle hex hole at each end 19mm?
Im looking at big allen wrenches and don't want a mistake on this buy.
"...just let go of the brakes and let the bike on through..." - Guy Martin
trackscoot22 is offline
post #63 of 83 (permalink) Old 10-21-2010, 10:34 PM
Went to the hardware store and took my '05 axle with to look at allen wrenches. The bolt head is 17mm, and the nut is 19mm. But they wanted $23.90 for one wrench! Then found a footlong 19mm allen on eBay for only 4.50, and still looking for a deal on a 17.
And still scratching head on why the 2 different sizes.
Thanks for threads like this.
post #64 of 83 (permalink) Old 06-30-2011, 03:54 PM
TheX's Avatar
Images: 2
Feedback Score: 5 reviews
Excellent write-up. Needed torque settings for the calipers and Google pulled this up.
TheX is offline
post #65 of 83 (permalink) Old 02-23-2012, 02:05 PM
droxile's Avatar
I was torquing down my front axle but it was spinning while I was torquing it down, so I had someone stick a wrench on the left side to hold it while I torqued it down. Is this correct? You guys never mentioned anything about having to hold the axle while you torque it down, and you said to torque the axle bolt before tightening the pinch bolts..
2008 CBR600RR: Reservoir Sock - Powdercoated seat - Power Steering - Passenger Emergency Brake Lever - Fender Extender - Foghorn - Carbureted Engine Mod
droxile is offline
post #66 of 83 (permalink) Old 03-17-2012, 08:59 PM
So is the left spacer the fat one?
stpierre is offline
post #67 of 83 (permalink) Old 03-23-2012, 09:50 PM
MrRager's Avatar
Figured this would be a good thread to ask this question,didn't want to make a whole entire new thread.
So,I'm wanting to install my new Galfer wave rotors,but I don't own a front stand.Was wondering if it's ok to use a jack,piece of wood,and cloth to jack up the bike where the midpipe is?
MrRager is offline
post #68 of 83 (permalink) Old 03-24-2012, 10:38 AM
Superhawk's Avatar
Invest in the front stand
trackday whore
2011 CBR600RR, 2009 125 Zuma
Superhawk is offline
post #69 of 83 (permalink) Old 05-07-2012, 05:56 PM
I just had to remove both my front and rear tires and this guide is FLAWLESS. Great description and pictures. Thanks BiGxbOix510.
sjreg1 is offline
post #70 of 83 (permalink) Old 05-07-2012, 06:55 PM
02gsxxr's Avatar
Feedback Score: 7 reviews
you are correct....
2000 ZX6R - sold due to immaturity
2002 GSXR - Sold
2001 F4i Stunt Bike - Sold *didnt have time to really get into the sport*
2007 600rr *White/Silver* - Totaled *Recent accident*
2007 600rr *White/Silver* - New Bike... had to have the same color
02gsxxr is offline
post #71 of 83 (permalink) Old 07-22-2012, 09:40 AM
maine_CBR's Avatar
OLD thread i know
bolt heads and nuts are different sizes so that way you don't need two 23.00$ wrenches of the same size. so if you bought a set of 10MM - 22MM you wouldn't need a second set just to get the bolt out. Make sense?
2003 CBR600RR - 21,250 MILES
LEO VINCE SLIP-ON
TARGA FENDER ELIMINATOR
FLUSH MOUNTS
PILOT ROAD2's
2W1R: Fire Starter
you saw that porno too!?
Obviously monkey directed it.
maine_CBR is offline
post #72 of 83 (permalink) Old 08-30-2012, 10:20 PM
sdiver68's Avatar
Originally Posted by Jim Moore View Post
It looks like it, but it is almost impossible to do.
Really? Use to do it all the time on my racing GSXR's...
sdiver68 is offline
post #73 of 83 (permalink) Old 04-14-2013, 04:43 PM
Lifetime Premium
JWRusk's Avatar
Feedback Score: 6 reviews
why do the front calipers have to come off?
2007 CBR600RR White/Black/Carbon Fiber SOLD*
2009 CBR1000RR/ABS Black SOLD*
2012 CBR1000RR/ABS White SOLD*
2015 CBR1000RR SP REPSOL
My Build threads:
07 CBR600RR Build:
https://www.600rr.net/vb/showthread.php?t=268061
09,12,15 Build:
https://www.600rr.net/vb/176-rr-other...ld-thread.html
JWRusk is offline
post #74 of 83 (permalink) Old 04-14-2013, 11:49 PM
Bridge_Jumper's Avatar
Most likely because when you put the front wheel back on you will be fighting against the brake pads if they have shifted a little from their position.
It's simple enough to remove the calipers... 2 bolts each
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
post #75 of 83 (permalink) Old 04-15-2013, 01:04 AM
Lifetime Premium
JWRusk's Avatar
Yah I took them with no problem. Just wanted to see if anyone knew the reason for it. Thanks though!
Sent from Motorcycle.com App
My Build threads:
07 CBR600RR Build:
09,12,15 Build:
JWRusk is offline
post #76 of 83 (permalink) Old 02-12-2014, 02:51 PM
Andywear's Avatar
this place is full of trolls-
EAD.
Andywear is offline
post #77 of 83 (permalink) Old 02-12-2014, 08:36 PM
Images: 4
Nice writeup. I just need to get a frontstand now
Mythran is offline
post #78 of 83 (permalink) Old 06-11-2015, 07:53 PM
I still come back to this thread every time to double-check tire removal. Thanks and well done.
sjreg1 is offline
post #79 of 83 (permalink) Old 06-25-2015, 05:55 PM
e90Mark's Avatar
Great writeup. Helped me get my front wheel off to get a new tire mounted.
Also followed the noted torque order for buttoning things back up. No issues.
2006 Honda CBR 600RR
e90Mark is offline
post #80 of 83 (permalink) Old 08-16-2015, 10:38 PM
Alexgoesvrooom's Avatar
Sorry to bring up an old thread but I just swapped my tires & when I pulled the front axle it was almost greaseless so after I greased it and finished installing I went for a ride and it took me by huge surprise how smooth/quick the bars turn left/right, is this how it's suppose to be? And it just took me by surprise cause mine was basically dry?
Comments thoughts? Thanks in advance
Alexgoesvrooom is offline
post #81 of 83 (permalink) Old 08-16-2015, 10:58 PM
03cbr-rider's Avatar
What are you asking? If greasing the front axle will help steer the bars easier?
03cbr-rider is offline
post #82 of 83 (permalink) Old 08-17-2015, 03:52 AM
OzMoto's Avatar
That's due to a new tyre. Caught me by surprise how easy the bike tips into corner with new Pilot Road 4's. I was too used to a squared off tyre.
Ride carefully - You are invisible.
FB | YT
I'd rather be next to a rider that can maintain a controlled wheelie than a muppet on their phone.
Current: 2012 Street Triple R
Sold: 2001 NSR150SP | 2012 CBR250R
RIP: 2003 CBR600RR
DIY:
OzMoto is offline
post #83 of 83 (permalink) Old 08-17-2015, 05:48 PM
Yea I meant to edit my post before people replied but oh well.
I was gonna say it seems that the bike wants to dip into corners so easily and I figured it would be due to having both new tires, I put on the Pirelli Diablo Rosso II's
