How To-Front Wheel Removal - 600RR.net
03 / 06 RR This forum is dedicated to all the How to write ups for 03 to 06 RR
post #1 of 83 (permalink) Old 05-21-2007, 12:42 AM Thread Starter
BiGxbOix510's Avatar
Images: 63
Since I did the write up for the rear, I got bored and did the front, too.
My How To for removing the front wheel from a 2005-2006.
WARNING NOW.
DO NOT TOUCH YOUR FRONT BRAKE LEVER AT ANYTIME DURING THIS PROCESS.
Tools from the toolkit. I had to use a few others to get some bolts off.
Hammer/Mallet, 12mm wrench, 14mm wrench, and 22mm wrench.
1. Support the front end of your bike. I'm using a pit bull front stand.
2. Loosen the 2 pinch bolts on the front axle bolt side FIRST.
3. Remove the axle bolt with a 22mm socket or the hard way with the tool from the kit.
4. Remove the two 14mm bolts on both front calipers and remove them.
5. Go to the other side and remove the 2 pinch bolts on that side.
6. Take a hammer or mallet and tap the axle thru the fork.
7. Lift the wheel up and pull the axle all the way thru.
8. Pull the front wheel out. Ding! Fries are done.
You should not hang your calipers by the brake lines/brake hoses.
Use bungee cords or zip ties to hang them from.
To Reinstall:
Originally Posted by Sete15 View Post
Yes, you DO need to torque up in a very specific order to keep the axle from binding which can happen, I've seen it before..... If you don't know how to do something properly-- don't pretend like you do and steer others in the wrong direction. That way you do everyone a favor. Here is the official Honda factory technician's procedure:
-Apply a thin layer of grease to the front of the axle rod & install axle from LEFT side of bike (your right side as you face the front of the bike)
-Torque axle bolt to the specified torque
-Tighten the right axle pinch bolts to specified torque.
-Install both brake calipers and tighten mounting bolts
-Check front brake operation by spinning wheel and applying brake pressure
-Lower the front of the bike, with the front brake applied, pump the fork up and down several times to seat the axle.
-Tighten the left axle holder bolts to the specified torque.
All done!
2005 600RR Black Metallic (I miss it already)
2008 GSX-R750
http://www.myspace.com/bigxboix510
Last edited by BiGxbOix510; 06-21-2007 at 01:57 PM. Reason: CORRECT Reinstall instruction.
BiGxbOix510 is offline
The Following 4 Users Say Thank You to BiGxbOix510 For This Useful Post:
aslcbr600 (07-20-2012), fiery_phoenix (06-04-2012), MaytagRacerMan (06-29-2013), yipperzz (08-15-2011)
post #2 of 83 (permalink) Old 05-21-2007, 12:50 AM
Whore Police
Wes600rr's Avatar
Feedback Score: 17 reviews
I like most others don't have a service book, I have however done this a few times. Some torque specs would complete the value of your time spent on the post...
Best Auto/Moto Insurance | Motorcycle Protection Today | FREE Trade-In Quote
RIP Phatty
Originally Posted by chipmunkofdoom2 View Post
Don't shout "I'M STUPID!" electronically, for all the Internet to hear, then get angry when we call you stupid.
Wes600rr is offline
post #3 of 83 (permalink) Old 05-21-2007, 12:55 AM
HondaRider4Life's Avatar
yea it helps to have the owners manual but again we all look out for each other on 600rr.net !!!!
2003 CBR600 RR (Black)
Polished Wheels
Galfer Braided Brake Lines
Yoshi Pipe RS-5
D.I.D 525 Chain
+3 Rear Sprocket/-1 Front
Pirelli Tires
Speed-O-Healer
www.myspace.com/fadim27
HondaRider4Life is offline
post #4 of 83 (permalink) Old 05-21-2007, 12:57 AM
Whore Police
Wes600rr's Avatar
Does the owners manual have all the torque specs in it? Never looked to see. I just call Slaps and ask him to go dig in the service Manual.
RIP Phatty
Wes600rr is offline
post #5 of 83 (permalink) Old 05-21-2007, 12:59 AM Thread Starter
Images: 63
Oh yeah, lol. Whoopsy. Thanks for the headsup. Here's the torque values.
2008 GSX-R750
post #6 of 83 (permalink) Old 05-21-2007, 08:01 AM
Hittin The Twisties On My RC 51
600RRyder1's Avatar
Nicely done. Sticky please.
600RRyder1 is offline
post #7 of 83 (permalink) Old 05-22-2007, 09:45 PM
chef babu's Avatar
very cool of you to post!
chef babu is offline
post #8 of 83 (permalink) Old 05-31-2007, 10:28 AM
Knightslugger
Posts: n/a
yes, plz sticky
post #9 of 83 (permalink) Old 06-20-2007, 08:46 PM
i know its an older sticky but i was wondering what the torquing sequence was for the pinch bolts.
for example on the 1000rr wheel you have to do one side bounce the forksl a few times to line everything up then the other side pinch bolts.
any ideas?
baxsom is offline
post #10 of 83 (permalink) Old 06-20-2007, 09:37 PM
Knightslugger
Posts: n/a
any ideas?
just torque them down...
post #11 of 83 (permalink) Old 06-20-2007, 10:27 PM
everything i have ever read has said that just torquing them down
not a good idea. if you dont do it in the correct sequence with the front end lined up the wheel will bind
baxsom is offline
post #12 of 83 (permalink) Old 06-21-2007, 12:42 AM
Knightslugger
Posts: n/a
i've never seen it or heard of it happening.
post #13 of 83 (permalink) Old 06-21-2007, 01:16 PM
Sete15's Avatar
All done!
Sete15 is offline
post #14 of 83 (permalink) Old 06-21-2007, 01:37 PM
Knightslugger
Posts: n/a
All done!
i've never seen a tech/mech do this once...
post #15 of 83 (permalink) Old 06-21-2007, 01:45 PM
Boosted Josh's Avatar
Then you've never seen me R&R a front wheel. Then again I'm not a tech or a trained mechanic but I do have a service manual.
:wav:
:wav:
:wav:
06 CBR600RR: Track Only
Ohlins 20mm supersport fork kit
Ohlins Shock
Woodcraft clipons
Renthal Grips
Vortex Rearsets
OES frame sliders
Motovation swingarm and axle sliders
Galfer lines and pads
Sharkskinz bodywork
Two Brothers Slip on
PCIII
GPR damper
Boosted Josh is offline
post #16 of 83 (permalink) Old 06-21-2007, 02:04 PM Thread Starter
Images: 63
Well, I went ahead and threw that info on there.
Do you also use new bolts for the brake caliper?
You're supposed to, I didn't...
Pray for me that I don't lose my brakes.
2008 GSX-R750
post #17 of 83 (permalink) Old 06-21-2007, 02:28 PM
I've pulled my front wheel many many times and reused the caliper bolts. Howerver I would say that you should replace them after you've pulled them maybe 10 times. I bought some new ones to use next time around. Be prepared to pay for them those caliper bolts are like $10 each. I'd rather replace them every once in a while than have one break and have to drill it out.
Ohlins Shock
Woodcraft clipons
Renthal Grips
Vortex Rearsets
OES frame sliders
Sharkskinz bodywork
PCIII
GPR damper
post #18 of 83 (permalink) Old 06-21-2007, 03:36 PM Thread Starter
Images: 63
This is maybe the 6th time the front wheel has come off the bike.
So it's gonna have to be changed soon.
Might not withstand the 22ft-lbs next time.
Part # for the front brake caliper mounting bolts.
2003-2004
90131-KBV-003 - BOLT, FLANGE (8X32)
2005-2006
90131-MEL-000 - BOLT, FLANGE (10X57)
You can order it via RonAyers or ServiceHonda or walk into your local dealership and pay some more.
2008 GSX-R750
post #19 of 83 (permalink) Old 06-21-2007, 03:42 PM
Knightslugger
Posts: n/a
2003-2004
2005-2006
probably all come out in the wash anyway... pay ronayers or service honda shipping, or pay the premium at the dealer... meh. i'd walk in.
post #20 of 83 (permalink) Old 06-21-2007, 03:49 PM
warrenjrose's Avatar
I know the front wheel of my bike's been on and off > 10 times and I haven't seen any wear on the caliper bolts. Throw them back on, add a little safety wire, why would you be concerned with replacing them?
LeoVince Exhaust Systems - Scorpion USA - Vortex Racing - Woodcraft CFM
'07 GSX-R600 - '05 CBR 600RR - '04 Ninja EX250 (sold) - '98 CBR 900RR
Nationally Licensed MSF Instructor
UtahSBA MoM #314
warrenjrose is offline
post #21 of 83 (permalink) Old 06-21-2007, 03:52 PM
Knightslugger
Posts: n/a
They are designed to stretch as they are tightened.
post #22 of 83 (permalink) Old 06-21-2007, 04:27 PM
that is why my brand new 600 wont even complete 1 turn on the front wheel when spun by hand
my 1000 was the same way and using the method described above it now turns 4 revolutions
i was thinking it was the same procedures but just wanted to make sure
baxsom is offline
post #23 of 83 (permalink) Old 06-30-2007, 12:44 PM
is this the same for the 07 cbr600
iraq 2006-2008
phaseshift is offline
post #24 of 83 (permalink) Old 06-30-2007, 06:50 PM
just bought the 07 service manual
to reinstall the front wheel per the manual p14-21
calipers off
axle in
tighten axle bolt to 44 ft/lbs
right side pinch bolts to 16 ft/lbs
both brake calipers on and tighten to 33 ft/lbs
apply brake and bounce forks up and down
tighten left pinch bolts to 16 ft/lbs
baxsom is offline
post #25 of 83 (permalink) Old 07-18-2007, 09:21 PM
firefighter11's Avatar
Hey guys, just wanted to say thanks for the info, I didnt have a front stand or so i kinda improvized.
wish i would have taken a picture for you guys, but all's i did was put a wratchet strap down my rear tire and around my rear stand and lifted the bike from it's center point with a jack that was for my truck (since i cant find my hydraulic jack) and the front came up no problem... took everything off, got my wheel changed and put it back on without a hitch.
03 RR
Micron Dual Out Exhaust
Blacked OEM windscreen
Blacked lowers
Blacked out 3rd eye
ASV shorty levers
DIY FE
Powder Coated: Clutch & Stator cover
PCIII USB with Micron Map
T-rex Frame sliders
Trippage LED P/C black rear pegs
Vortex 520 conversion with Gold X chain
Corbin Seat
firefighter11 is offline
post #26 of 83 (permalink) Old 07-18-2007, 09:41 PM
"Superman dat hoe"
DirtyD916's Avatar
awesome write up. Have always wondered about this and it seems very simple actually. Cheers
Two Bros C5, Puig DB, Pazzo Shorties, LP Flushies
Shock Racing rear turn signals
Scotts Steering Damper
DIY polished rims, F/E, Black Swingarm/Cases
Adjustable Heated Grips (kickass!)
TSX Projectors with Denso Ballasts, Philips 4300K bulbs, and a custom harness
Originally Posted by ojonnyko View Post
you might not be able to get water from a rock, but if you use your laser vison you can get magma, and magma is way cooler then water.
DirtyD916 is offline
post #27 of 83 (permalink) Old 08-12-2007, 07:58 PM
ChemiKaze's Avatar
YES!!! I have been looking for this... now I want a rear wheel write up please!
For Sale:
Replica HRC 07/08 Honda CBR600RR Racing Number plates ($30 shipped):
Replica 07/08 Honda CBR 600RR Big Wings for upper and tank fairings ($60 shipped)
07CBR600RR: AK20 cartridge, Elka 3-way Shock, Bazzaz TC w/ AFM, Leo/Arrow Full, STM Slipper, Gilles VCT, Buck's custom dash, etc..
Team Blue Plate Teacher rider!!
ChemiKaze is offline
post #28 of 83 (permalink) Old 08-13-2007, 03:56 PM
do you have to remove the calipers? look like they would slide in and out.
SilvaRR is offline
post #29 of 83 (permalink) Old 08-28-2007, 05:42 AM
Jim Moore's Avatar
Feedback Score: 9 reviews
It looks like it, but it is almost impossible to do.
Jim Moore is offline
post #30 of 83 (permalink) Old 08-28-2007, 06:14 AM
Slyder's Avatar
Feedback Score: 25 reviews
also u can download the service manual from my site as well....
03-04 Service Manual
shouldn't be too different for the 05-06
getting back in the game.
Slyder is offline
