How To Paint Your Engine Cover.... - Page 3 - 600RR.net
07 / 013 RR This forum is dedicated to the How to write ups for 07 / 013 RR
post #61 of 94 (permalink) Old 05-25-2009, 10:13 AM
I got a quick question. I have never worked with a dremmel before, how big is the learning curve with this tool? I am a pretty handy guy and the scratches on my engine covers are driving me crazy. I am sure I will try this no matter what just kinda curious about what i am in for......thanks
jtaddeo07 is offline
post #62 of 94 (permalink) Old 05-25-2009, 01:57 PM
Dremel isn't the ideal tool for sanding, but if you use the wire brush its more forgiving.
If the damage is too deep, use a body filler like bondo.
Sand(heavy), fill, sand(180), prime, sand(600), paint away!
Anik321 is offline
post #63 of 94 (permalink) Old 05-25-2009, 10:19 PM
bondo can stand the heat from the engine? if so that sounds alot easier than trying to grind scrapes out of metal...........thanks for your help
post #64 of 94 (permalink) Old 07-25-2009, 04:16 PM
white07rider's Avatar
for those who have done this: how long after you painted the cover did you wait before running the engine? i plan on doing this but it doesn't say on the can. i have duplicolor engine enamel
white07rider is offline
post #65 of 94 (permalink) Old 10-03-2009, 07:45 PM
Sorry to bump an old thread, but thought it would be better than getting the "use the search" comments since this is the thread I would need to have searched.
Anyhow, I was wondering if that paint was the Dupli-Color Low Gloss Black Engine Enamel (DE1634)? That is the only Dupli-Color high temp paint that I could find that seemed to be fairly close to the engine color. Could it have been the DH1602 that I found listed on Dupli-Colors website that I couldn't find at the store?
Thanks in advance!
str33t_fir3 is offline
post #66 of 94 (permalink) Old 11-21-2009, 07:14 AM
btr
btr's Avatar
awesome idea, i will try this!
btr is offline
post #67 of 94 (permalink) Old 01-10-2010, 08:54 PM
kcafik's Avatar
You inspired me to do my covers....took them off the bike though. Thanks for the great write up
kcafik is offline
post #68 of 94 (permalink) Old 03-08-2010, 12:59 PM
jarhead89x's Avatar
In the pictures, only the smaller circle portion is sanded. Is that the only part that I need to sand or do I need to sand down the ENTIRE case (both big circle and little circle)?
jarhead89x is offline
post #69 of 94 (permalink) Old 03-08-2010, 06:28 PM
Pure's Avatar
you need to sand down the whole cover both of them, its gives the paint grip.
1) - Sand the whole cover with 220 grit.
2) - Use acetone to clean the area you just sanded, also use gloves and well vented area so you don't breath it in acetone
3) - Use soap and water to clean off any excess of acetone.
4) - Now apply a coat of paint when surface is dry, don`t add to much so it runs but enough it coats the whole area.
5) - wait 30-45 minutes for the first coat to dry.
6) - Add another coat of paint.
7) - Wait 30-45 minutes to dry.
8) - Add another coat of paint.
9) - Wait 30-45 minutes to dry.
10) - Use 1000 grit wet sand paper.
11) - Use soap and water to clean the area off.
12) - Now apply the last coat of paint.
13) -- wait till it is fully dry and look at it, does it look good, if not then re-apply another coat.
14) - Congratulations you are done!!!
Pure is offline
post #70 of 94 (permalink) Old 03-09-2010, 02:51 PM
Brawlz33's Avatar
I'm think of trying this, I don't know though I'm not a good painter. How hard was this to do?
2008 CBR 600RR RED/BLACK
Brawlz33 is offline
post #71 of 94 (permalink) Old 03-09-2010, 03:00 PM
shyne47's Avatar
great job and great pics
TEAM BLACK
shyne47 is offline
post #72 of 94 (permalink) Old 03-09-2010, 05:32 PM
Pure's Avatar
its not hard, just make sure you sand the whole area and do the steps.
The way you paint is you do spirts, spray and count to 1 stop, in a sweeping motion till the area is all hit, and do that for every other coat.
Really its like swinging your arm and hit the spray and hold it for one second.
Pure is offline
post #73 of 94 (permalink) Old 04-12-2010, 07:23 PM
Thanks for the suggestion!
I believe I posted on this last year for some instructions how to do this.....just want to say I did and it turned out awesome! I repainted both covers a darker shade of gray and you can't even tell they were scraped except for my clutch cover b/c it had a really deep mark. I would post a pic but I dont have one!
post #74 of 94 (permalink) Old 04-23-2010, 12:21 PM
Themouse's Avatar
looks great man never thought that it would come out that good definitely going to keep this in mind
If you're going to advertise your business in your sig, you will need to acquire vendor status on .net.
-RawRR
Themouse is offline
post #75 of 94 (permalink) Old 04-23-2010, 01:24 PM
dadizfoshiz's Avatar
Images: 2
nice work on all!!
-diz-
dadizfoshiz is offline
post #76 of 94 (permalink) Old 05-18-2010, 01:12 AM
hoodie's Avatar
going to do this as soon as i have time to! :D
hoodie is offline
post #77 of 94 (permalink) Old 07-11-2010, 11:48 PM
took me about 2hours for this whole process. sanding/prepping the 1st hour, and the other hour i sprayed it with 10min intervals in between. left it for about another hour or so, then rode around so that the heat from the engine would cure the paint. its been over a month and it looks rock solid!
rk604 is offline
post #78 of 94 (permalink) Old 07-11-2010, 11:54 PM
How much are new case covers anyway? I dont have a dremmel, but if the cost is similar... woul be best to to buy a dremmel for future projects!
2008 CBR 600RR
Kildore is offline
post #79 of 94 (permalink) Old 07-15-2010, 08:00 PM
AstroPenguin's Avatar
nice! i just ordered a new cover for 140 bucks. but i'll take off the scraped one and fix it up to sell and keep the new one :)
2007 Honda CBR600RR - Pearl White
Pearl White seat cowl
Akrapovic Slip-on (Titanium w/ blued midpipe)
BMC Air Filter
Bridgestone S20 tires
Driven 520 Conversion (-1 +2)
Puig Double Bubble (Dark Smoke)
ASV Shorty Levers
Woodcraft Rearsets
Motydesign custom gauges w/ Acumen Gear Indicator
Motydesign 8-cell Battery
HRC Throttle cables & housing
Rizoma Grips & bar ends w/ 1/6th turn throttle
Tripage Smoked IT
Watsen Flushmounts
Black Majik Carbon Fiber huggers and tank panels
AstroPenguin is offline
post #80 of 94 (permalink) Old 08-04-2010, 10:43 AM
laid my bike recently. I need to do try this.
heatjay is offline
post #81 of 94 (permalink) Old 08-04-2010, 06:56 PM
baypistolman72's Avatar
That looks good mang! I need to do that to the stator and the clutch cover. Hmmm...
Live the Life you Love and Love the Life you live.
baypistolman72 is offline
post #82 of 94 (permalink) Old 08-10-2010, 03:16 PM
kain101's Avatar
Thanks I am gonna do the same now
Update:
Just finished, it looks great. only if you are up close can you notice some of the imperfections where the metal was gouged. from 2 steps back it looks just like it came from the factory. I was gonna spend a ridulous amount on new covers but for less than $25 i got everything i need to breath new life into the bike
kain101 is offline
post #83 of 94 (permalink) Old 12-28-2010, 12:29 AM
redlinernyc's Avatar
Feedback Score: 14 reviews
just curious why you guys never mentioned applying primer after the initial sanding down of the surface. Is it because the paint sticks anyway to a sanded surface?
Black 2006 600rr l SOLD Dec 2010
07 600rr - sold Aug 2011
07 white/silver 600rr - sold
Current: 2015 1000rr
redlinernyc is offline
post #84 of 94 (permalink) Old 03-18-2011, 03:43 PM
laxking24's Avatar
great job! I just bought my bike with some scratches on the cover and was looking for a way to clean it up, I'll definitely try this thanks man!
laxking24 is offline
post #85 of 94 (permalink) Old 06-04-2012, 05:16 AM
Pure's Avatar
prim is ok if you got huge dips in the cover but if you got that deep of ones I would just replace it because who knows if you might have a crack. It's all up to what you want to do but high temp paint works like a charm without prim.
Pure is offline
post #86 of 94 (permalink) Old 01-28-2013, 03:44 AM
Hey Dave,
awesome job! I just found your thread and have some questions if you still remember:
1. Did you remove the small cap for dremelling?
2. If yes, how did you prevent small metal fragments getting into the engine when dremelling the edge of the whole?
3. Did you paint the small cap separately or screwed back and painted together with the big piece?
4. If U get it right, you dremelled the scratched parts (where metal can be seen) and sand papered all the engine cover (but left the original paint on on the unscratched parts). Is this correct?
5. You say you used DH 1602 High Heat Black paint. Is that right? (I found also two other types of paint that might be similar: DE 1634 Low Gloss Black, DE 1651 Cast Coat Iron - I might order both to see the difference, I d love to have it as close to origi as it can be.)
Sorry for the many questions, but I am very excited and want to to the job right. Thanks for your help!
chill
chill73 is offline
post #87 of 94 (permalink) Old 02-02-2013, 11:45 PM
highonlakai's Avatar
wicked! Totally doing this to my right hand case, thanks for the write up!
2007 600RR - Konica Minolta rep (SOLD).....
2008 Fireblade - (SOLD)
2013 848EVO - (SOLD)
Build thread; https://www.600rr.net/vb/showthread.php?t=350770 ....
highonlakai is offline
post #88 of 94 (permalink) Old 05-11-2013, 08:06 PM
45pro's Avatar
Exactly what color paint did you use? I need to do this to my stator cover. I'm going to spray it while on the bike.
Sent from Motorcycle.com App
45pro is offline
post #89 of 94 (permalink) Old 05-12-2013, 02:35 PM
Treys's Avatar
I have similar damage I need to try this
Treys is offline
post #90 of 94 (permalink) Old 07-28-2013, 07:06 PM
mckain87's Avatar
I haave the same exact damage. What does wet sand mean though?
***Mack***
2008 Honda CBR600RR Build
https://www.600rr.net/vb/showthread.p...49#post4915049
mckain87 is offline
