DIY: Dual headlight with switch, LED running lights - 600RR.net
07 / 013 RR This forum is dedicated to the How to write ups for 07 / 013 RR
post #1 of 27 (permalink) Old 08-12-2009, 09:44 PM Thread Starter
HighlyFavored0420's Avatar
I'm going to attempt a small write-up to inform all of you how to set up dual headlights, being able to switch them off, and using LED's as running lights with the headlights off. This can probably be done with regular headlights as well, but you will need to cut off the stock connector and run the wires accordingly. I won't get into the install of the HID's or LED's as there are many already on here. This is specifically how to be able to switch the headlights on and off using your H/L switch, and turning on and off LED's using the same switch. Here were go...
Materials needed:
5-pin Relay ( I sourced mine from a local car audio shop for $5)
18 ga wire (I found a 3-pk of wire, r,blk,grn for around $7 @ Radio Shack
18 ga 1/4" Male/Female clips (Radio Shack, $3 or so)
18 ga Quick Splice Connectors
Voltmeter
Electrical Tape
Zip Ties
First step is to remove the + terminal from the battery. This will ensure and wires accidently touching won't spark or fry your bikes wiring.
Here is how the 5-pin relay will be setup.
Next, we need to find and splice into the trigger wire to activate the relay. It can be found on either side of the bike, near the big grey harness next to the gas tank. This is for an 08, but I'm sure the 07 is the same. Mine was a solid blue wire with silver dots on it. I would advise to use a Voltmeter and test this for yourself by piercing the blue wire, turning the bike on and switching the high beams on and off and confirm the voltage change.
After you have found the wire, use a quick splice connector, and run enough wire to make it underneath the seat to the battery. This will connect to Pin-86.
Next we need a wire to connect to the + and - of the HID's. Using a female connector, attach the wire to the male end provided with the HID's. Run both of these to the seat area. The + will be Pin-87, and the - will be Pin-85.
I quick spliced into the ground of the HID's for the LED's, and ran the postive wire of the LED's to the seat area. This will be Pin-87a.
A ground from the battery will be added to the HID ground and connected into Pin-85. This may be unnecessary, but it will assure a good ground.
Lastly, using your voltmeter, test the wires in the fuse box underneath the seat and chose a wire that has power with the Key on, and no power with the key off. Quick splice into this wire. This will be Pin-30.
After everything is wired up, use the zip ties to secure your new wiring to the existing stock wiring. This is made easier with the has tank and side fairings removed, but can probably be done with them still on. The electrical tape comes in very handy near the headlights because it will hide the new wires and make them appear factory. The relay will sit underneath the seat on the right side, there is a small void just big enough for the relay.
I apologize for the lack of pictures, I did this install while also installing fairings, and didn't take the time to take detailed pictures.
After everything is secured and taped, re-attach your + terminal to your battery and fasten the seat down. Test out your new setup!
Credit goes out to Tripage, MAJOR thanks to High Voltage RR, and iSteveO's thread here https://www.600rr.net/vb/showthread.php?t=143368
'08 motofans custom - crg, akra, puig db, watsens, audi, IT tail light, tripage fe & gas cap, r&g, ddm
DIY HID on/off switch with LED running lights: https://www.600rr.net/vb/showthread.php?t=150450
HighlyFavored0420 is offline
The Following User Says Thank You to HighlyFavored0420 For This Useful Post:
SHAdoh (03-19-2012)
post #2 of 27 (permalink) Old 08-13-2009, 03:23 PM Thread Starter
Update: Uploaded a video to YouTube. http://www.youtube.com/watch?v=xEJmpSoDzeI
post #3 of 27 (permalink) Old 08-13-2009, 03:38 PM
Sadt3arZ's Avatar
Feedback Score: 14 reviews
nice write up man but maybe u can get some pics to go along with all this info. i know when i did mine it was a pain in the a$$ and pics would definately fill in some of the blurr spots of the install.
Sadt3arZ is offline
post #4 of 27 (permalink) Old 08-13-2009, 03:56 PM Thread Starter
I agree, but unfortunately I didn't take any. iSteveO's thread does have a massive amount of pics and can show the areas that need to be shown.
post #5 of 27 (permalink) Old 08-13-2009, 04:00 PM
Sadt3arZ's Avatar
these are spdt relays that you're using right? if anyone needs some relays i have 2 brand new bosch relays with male and female connectors for sale. i bought it for the same project but ended up not using them. these are perfect because u won't need to buy connectors, and tape the crap out of ur relays. wire one end into the male and the other into the female and they just mate together for a professional look
Sadt3arZ is offline
post #6 of 27 (permalink) Old 08-13-2009, 04:11 PM Thread Starter
Yes they are. And every relay I've seen looks the same. Has pins out of the bottom to accept a female connector or has a few wires already coming off of it that you have to attach another wire to. 6 in one half dozen in the other.
post #7 of 27 (permalink) Old 08-13-2009, 04:19 PM
tripage's Avatar
Feedback Score: 91 reviews
Looks great. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #8 of 27 (permalink) Old 08-13-2009, 04:28 PM
Banned
Looks awesome man. Glad I could help.
HIGH VOLTAGE RR is offline
post #9 of 27 (permalink) Old 08-13-2009, 04:30 PM Thread Starter
Glad that both of you guys helped me! Couldn't have done it without the both of you.
post #10 of 27 (permalink) Old 08-15-2009, 05:28 AM
Looks awesome man... nice work!
jmanfive40 is offline
post #11 of 27 (permalink) Old 08-27-2009, 10:53 PM
wowwwwwwwza...LOVE how the LED's fire up just like the HID's.....bravo
kneedraggin is offline
post #12 of 27 (permalink) Old 08-27-2009, 11:01 PM
ProWakeskater's Avatar
hey where did you get the quick connector T's? Radio shack?
ProWakeskater is offline
post #13 of 27 (permalink) Old 08-28-2009, 07:33 PM Thread Starter
Yep. I sourced all of the connectors from Radio Shack, and the 5-pin relay from my local audio/alarm shop.
post #14 of 27 (permalink) Old 05-27-2010, 12:30 AM
JC_600RR's Avatar
Can anyone give me a hand i'm located in the Miami area, i want to go HID but both light at the same time anyone? i'll pay for labor!
JC
2009 CBR 600RR
JC_600RR is offline
post #15 of 27 (permalink) Old 05-31-2010, 11:18 PM Thread Starter
You can run an extension and plug the power/ground into the high beam from the low beam. I'm not sure if there are any power issues related, but it's a fix if there aren't any. I'm sure it can be done with the use of a 4-pin relay with the high beam triggered (same as the instructions posted above) as well, but I'm not sure how savy you are with doing that sort of work.
post #16 of 27 (permalink) Old 10-06-2010, 11:43 PM
Ryry's Avatar
Would the wiring be the same for an 07?
Ryry is offline
post #17 of 27 (permalink) Old 11-24-2010, 01:04 PM
MotleyRepsolRider's Avatar
It sounds like I got a weekend project coming....sweet..
MotleyRepsolRider is offline
post #18 of 27 (permalink) Old 03-19-2012, 05:47 AM
BOTM Winner 09/13
SHAdoh's Avatar
Thanks to the OP! This is exactly what I was looking for!
My install took longer than expected though.. I over thought my process..
Question though.. are we supposed to only use 1 relay? Are there different watts/amps for each relay? I only hooked up one.. works fine.. but curious & worried..
SHAdoh is offline
post #19 of 27 (permalink) Old 03-19-2012, 06:01 AM
Marsplay's Avatar
Awesome! Tnx man!
2009 Honda CBR 600RR Phoenix Edition - Weekend Cruiser
2006 Infinity G35 - Daily Driver
Marsplay is offline
post #20 of 27 (permalink) Old 04-18-2012, 03:46 PM
bananamane's Avatar
Has anyone done this on the older CBR's specifically an 03? Im looking to to this and the LED's this weekend.
2003 RR Black
DIY Stacks
Yoshi S/S
Hotbodies Flushmounts
C/A Integrated Taillight
Pilot Power 2CT
H/M Fender Eliminator
Puig DB Dark Smoke
Brembo 15cc Reservoir
PC III
Gear Indicator
GPR Damper
Pazzo Levers
Goldeneye HIDS
vortex spools
Painted Black
Lowers
Rearsets
Engine cover
gas cap
bananamane is offline
post #21 of 27 (permalink) Old 04-18-2012, 05:05 PM
tripage's Avatar
Wanted to put this out as our new delay relay is almost ready. We have a new delay relay that will be able to delay dual Hid's or bulbs. What does this mean?
You will wire our delay up to your low beam and you can connect your high and low beam to the other side. Very easy install, no relays to wire up no additional wire to use. Look for this in the coming weeks. Only delay relay on the market that does not need to connect to the battery for it to delay your headlight from coming on when you turn the key on!!!!!!
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #22 of 27 (permalink) Old 05-15-2015, 09:57 AM
hey, sorry for reopening an old thread! just have a quick question. im using this mod to do something similar. i wanted to use the hi/low switch to control my LEDs that are all over my bike. so what im trying to accomplish is, lo beam, both lights are on (hi and lo), when i switch to high beam, both lights and LEDs are on. so i wired up the relay and the only way to get this to work is if i put the positive leads from the headlights on both pins 87 and 87a but when i do that, my LEDs just stay on. Can this be prevented if i put Diodes on leads? kinda the same way you would wire up turn signals to have running lights. If yes, what current rating Diodes would i need to get? thanks so much!!
jefftripz is offline
post #23 of 27 (permalink) Old 05-15-2015, 02:18 PM
tripage's Avatar
You could but the diode isn't the most effective way to do it. You can use our dual headlight module and wire the led's to the high beam + and you should be all set
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #24 of 27 (permalink) Old 05-15-2015, 02:50 PM
well i already have the relay wired up. thinking about it now, can i just use the hi/low trigger wire as my power source for the LEDs and just leave my lights wired to the relay for power source? i don't have an actual hi beam anymore, i put a regular bulb in and adjusted the position to just always have both lights on at the same time. i read on the forum to use the relay for power source because its better than running the + on both headlights to the bikes original relay.
post #25 of 27 (permalink) Old 05-15-2015, 03:24 PM
tripage's Avatar
It all depends how it's wired. If you have a double poll relay you can use the other leg for the led's.
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #26 of 27 (permalink) Old 05-15-2015, 03:39 PM
Gonna play around with it and see if I can get it working the way I want it to... thanks so much for your help! :-)
post #27 of 27 (permalink) Old 01-10-2017, 02:19 PM
I have some side emitting strips which i want to use as my running lights and have the headlights off when bike is ON -
I want my hi/low switch to turn on my HID HIGH BEAMS
Can someone make one these for me and i will pay you , i have no knowledge of electrical stuff /relays. If interested ,you can send me a message or reply below.
JXHennessy is offline
