How To: PSR Rear Brake Reservoir - 600RR.net
07 / 013 RR This forum is dedicated to the How to write ups for 07 / 013 RR
post #1 of 26 (permalink) Old 11-04-2013, 06:09 PM Thread Starter
Honderr's Avatar
This is a quick write up on how to install the PSR rear brake reservoir on 07-08 CBR 600RR models. First thing to look at is if you have aftermarket rearsets. If you do there is a good chance you will have to grind some of the heel guard off (1-2mm) on the backside. If you do not want to do this then I don't recommend the PSR res. If that's not a problem read on!
Before you move on make sure you understand how to bleed your brakes as that will be required at the end. Here is a how to on that:
https://www.600rr.net/vb/showthread.p...brake+bleeding
That is just one of many out there. Youtube has some videos as well.
Tools needed:
Phillips Head screwdriver
Allen Wrench/key(I think it was a 4 or 5)
Shop rags
Dremel or other small portable grinder with grinding attachment
All the tools needed for brake bleeding
1. Disconnect the OEM rear brake res and dump out the fluid
2. Bleed the brakes
3. Remove the phillips head bolt that connects the brake res line to the master cylinder and remove the attachment. Have shop rags handy as some residual brake fluid make drip out. DO NOT LET BRAKE FLUID GET ON PAINT OR PLASTICS!
4. If the O-ring came out with the hose take that off as it will be used with the PSR res. You can buy a new O-ring if you wish. If you reuse it check for splits/cuts in the O-ring to ensure you don't have any leaks.
5. Place the O-ring on the PSR res or in the master cylinder and push the res on.
'07 CBR 600rr
'11 MV Agusta Brutale 1090RR
Build Thread-Come on, do it! DO IT! What are you waiting for!?
Honderr is offline
The Following 2 Users Say Thank You to Honderr For This Useful Post:
flyn5flynn (12-12-2013), Wile Rider (11-05-2013)
post #2 of 26 (permalink) Old 11-04-2013, 06:21 PM Thread Starter
Honderr's Avatar
6. Check to see if the bolt hole lines up with the master cylinder hole. If you are in luck and the bolt installs you don't have to modify your rearsets at all. If it's an OEM rearset you can probably get away with just bending the heel guard out to get the extra mm you need. In my case I have vortex rearsets and had to grind some of the back of the reatset off.
If you do have to do any grinding make sure both holes on the master cylinder are blocked off. You don't want to get metal shavings in your master cylinder.
7. Once you have got it bolted on go ahead and check to see if your brake line will fit between the top of the res and the locating tab on the master cylinder.
In my case it did not so I had to get the dremel back out and grind some of the locating tab off. Again make sure holes are covered! This is what it looks like when finished.
All that is left now is adding fluid and bleeding your brakes! As you can see I had both aftermarket lines and rearsets. One other member (Dynarex) had OEM lines and still had to grind the locating tab. You might get lucky and not have to do any of that.
Hope this helps you guys out
'07 CBR 600rr
Honderr is offline
post #3 of 26 (permalink) Old 11-05-2013, 04:32 PM
JTRC51's Avatar
Nice.. I may need to get this now that my exh burned through my outer protective sleave on my line.
JTRC51 is offline
post #4 of 26 (permalink) Old 11-05-2013, 04:32 PM
JTRC51's Avatar
It didn't burn through the line itself but will if I don't fix it.
Nice writeup!!
JTRC51 is offline
post #5 of 26 (permalink) Old 11-05-2013, 04:38 PM
Wile Rider's Avatar
This is really going to help me out, thanks man
Wile Rider is offline
post #6 of 26 (permalink) Old 11-05-2013, 04:43 PM Thread Starter
Honderr's Avatar
No problem guys. If you got any other questions let me know
'07 CBR 600rr
Honderr is offline
post #7 of 26 (permalink) Old 11-05-2013, 04:52 PM
I wish those brake reservoirs were available in black.
MrLister is offline
post #8 of 26 (permalink) Old 11-05-2013, 06:29 PM
JTRC51's Avatar
Nothing a lil black paint wont fix ;)
JTRC51 is offline
post #9 of 26 (permalink) Old 03-10-2014, 09:21 PM
Just wondering how the PSR reservoir is going? Have you had any issues with leakages or anything?
I'm tossing up between a PSR or a G-craft. I like the fact the PSR has the window so am leaning slightly more towards that at the moment.
jarrodirwin is offline
post #10 of 26 (permalink) Old 03-10-2014, 09:32 PM Thread Starter
Honderr's Avatar
Haven't had road time on it yet. My PCV comes this week so this weekend will be the first time I get it on the road more than just up and down the street. I've pumped the brakes multiple times after I bled them just to make sure the line hasn't gone soft and no issues
'07 CBR 600rr
Honderr is offline
post #11 of 26 (permalink) Old 09-03-2014, 06:22 PM
EuroTrip's Avatar
Thread revival!
I'm planning on getting one of these, and noticed they don't come in black. Would it be possible to have it powder coated or is that a bad idea (and why?)? If it's safe, I'm just going to get whatever colour is in stock and have it PCed black.
EuroTrip is offline
post #12 of 26 (permalink) Old 09-03-2014, 06:28 PM
BOTM Winner 03/14
D1stylz's Avatar
Originally Posted by EuroTrip View Post
Thread revival!
They are anodized so you would have to get it anodized. Now if you paint or PC it it will chip but you might get lucky and it'll be fine.
Ps I have near 2k miles up and no problems still looks great and works a charm.
My simple build.
RIP SpdyG_AK 22 June 2014
D1stylz is offline
post #13 of 26 (permalink) Old 09-03-2014, 07:00 PM
EuroTrip's Avatar
Hmmm, so I'll have to find a local anodizing guy now too. Making my life that much harder D1 :P
EuroTrip is offline
post #14 of 26 (permalink) Old 09-09-2014, 09:25 PM
Black & Blue
They have a few colours. I just picked up the gunmetal grey.
http://stores.sportbiketrackgear.com...l.bok?no=29914
Haru - 2007 Black & Blue & Silver
| TST Industries | Tripage LED | Hindle | Toce | Spiegler | PSR | KingTech | DynoJet | Factory Pro | Shorai | Driven | HealTech | SkutrNet | Zero Gravity | Honda Racing | Pit Bull |
jme6hundy is offline
post #15 of 26 (permalink) Old 09-09-2014, 09:39 PM
EuroTrip's Avatar
Yeah, but I don't want that, I want black :P
EuroTrip is offline
post #16 of 26 (permalink) Old 09-09-2014, 10:01 PM
Black & Blue
Lol! It's OK honey! I'm sure we can find you a black one. :)
post #17 of 26 (permalink) Old 09-09-2014, 10:13 PM
EuroTrip's Avatar
PSR doesn't make it in black. I'll have to get it powder coated or something.
EuroTrip is offline
post #18 of 26 (permalink) Old 09-09-2014, 10:15 PM
Why didn't you just space out the heel guard with a couple little washers?
wibbly is offline
post #19 of 26 (permalink) Old 09-23-2014, 01:37 AM
Black & Blue
You could but you would also have to space the pivot bolt at the back of the brake lever in order to keep the M/C in line. Because there is a safety pin on that bolt, I'm not sure if there is the room to do it.
I just installed mine and had to grind the locating tab to get the brake line on the M/C. I also put a set of Spiegler SS brake lines on and added some speed bleeder screws.
http://stores.sportbiketrackgear.com/Detail.bok?no=5089
This how to was great and it really cleans up the back of the bike.
post #20 of 26 (permalink) Old 09-25-2014, 01:11 PM
Interesting, that looks kinda neat.
le0nng is offline
post #21 of 26 (permalink) Old 05-11-2015, 12:13 PM
biglen's Avatar
Images: 5
Feedback Score: 9 reviews
how did you get your vortex hardware red in color? i like that.
biglen is offline
post #22 of 26 (permalink) Old 05-17-2015, 06:36 PM Thread Starter
Honderr's Avatar
Metalcast paint from duplicolor. Gives them an anodized look. It's held up pretty well but I'm never going through the hassle of painting all my bolts again.
'07 CBR 600rr
Honderr is offline
post #23 of 26 (permalink) Old 07-31-2015, 09:31 AM
Thx
Great write up, thanks!
jayski is offline
post #24 of 26 (permalink) Old 02-09-2016, 10:26 PM
Chazzz's Avatar
Threadbump
Anyone install this Res with Woodcraft Rear Sets? Just curious if those would require trimming as well. We already know the Vortex ones do.
2012 Honda CBR 600RR
Chazzz is offline
post #25 of 26 (permalink) Old 04-13-2016, 01:49 AM
Cory Gillmore's Avatar
Feedback Score: 5 reviews
Just ordered the PSR reservoirs in anno red for the front and the back along with a set of front/rear Core Moto lines. Going to attempt the install this weekend so long as the parts come in before Saturday. Should be quite interesting as I've never even bled brakes before. But I have been studying thoroughly the past two days thanks to the link you provided and countless YouTube videos. I'm thinking if I can just get all the OEM lines and reservoirs removed without ruining my bike from brake fluid exposure that's half the battle lol. But thanks for this write up, it was a major factor in deciding weather to buy the rear res or not.
Cory Gillmore is offline
post #26 of 26 (permalink) Old 04-17-2016, 12:27 PM
Got everything done yesterday and it went super smooth. Question, how full do you fill that rear res? Anyway, love the look of that rear res. How'd you get rid of the OEM rear res mounting bracket on your bike?
ID:	177682   Click image for larger version
ID:	177690   Click image for larger version
