Gear shifter - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 13 (permalink) Old 12-24-2017, 07:23 AM Thread Starter
cips007's Avatar
Gear shifter
Hi guys
Iíve not long bought a Cbr600rr 2003 and have noticed the gear shifter is quite loose on the shaft. Iíve checked the shaft and no play,so am assuming itís the alloy gear shifter bore has worn,is this a common problem or have I something to worry about?
Thanks
cips007 is offline
post #2 of 13 (permalink) Old 12-24-2017, 02:43 PM
Honda-Power's Avatar
My shaft wiggles a little bit. If you post a video of it I can tell you if it's excessive or normal.
2003 Honda CBR600RR
- Renthal Sprockets (15/45) - DID 520ERV3
- Micron Slip on - Pair/EVAP delete
- SS front brake lines - Gilles Rearsets
Honda-Power is offline
post #3 of 13 (permalink) Old 12-25-2017, 09:28 AM Thread Starter
cips007's Avatar
Hi
Thanks for your reply
Iíve had a closer look and the actual shaft is fine,but the gear shifter/lever is loose on the pivot bolt that screws into the end of the shaft,looks like Iíll need a new gear shifter!
cips007 is offline
post #4 of 13 (permalink) Old 12-25-2017, 10:30 AM
498cm3's Avatar
cips007 my '05 is like that, hasn't been a problem, but I suppose maybe I should have another look at it.
Sent from my XT1031 using Tapatalk
498cm3 is offline
post #5 of 13 (permalink) Old 12-25-2017, 11:58 AM Thread Starter
cips007's Avatar
498cm3 Itís probably the alloy thatís worn on the gear changer hole,so am going to replace the lever and the pivot bolt that fixes through the centre of the lever.
Thanks guys
cips007 is offline
The Following User Says Thank You to cips007 For This Useful Post:
498cm3 (12-25-2017)
post #6 of 13 (permalink) Old 12-25-2017, 12:28 PM
498cm3's Avatar
OK thank you, I'll likely be doing the same. First I will check the retainer bolt and the condition of the splines.
498cm3 is offline
post #7 of 13 (permalink) Old 12-25-2017, 02:12 PM
Be careful, never use hammer on shift shaft.....
Why?
use search OTF!
tary preisser is offline
The Following User Says Thank You to tary preisser For This Useful Post:
498cm3 (12-25-2017)
post #8 of 13 (permalink) Old 12-25-2017, 02:45 PM
498cm3's Avatar
Tary I recall that procedure, and thought of it when this thread came up. I wondered if ham fisting would cause the aforementioned looseness...
498cm3 is offline
post #9 of 13 (permalink) Old 12-25-2017, 04:42 PM
i think he's talking about the actual shift lever, not the adapter that spines onto the shift shaft.
the slop is caused by wear. it's just a simple shouldered bolt and bushing fitment, so as things pack out it'll get loose.
OP it probably won't cause any trouble, but you could look into fixing it. i don't know off the top of my head, but is there a bushing in there? if not you could look into drilling out the shifter and installing a brass bushing to tighten things up
wibbly is offline
498cm3 (12-25-2017)
post #10 of 13 (permalink) Old 12-30-2017, 03:08 PM Thread Starter
cips007's Avatar
It looks like mine is sloppy due to either the bore of the shifter has worn or the pivot bolt,so have just ordered a replacement of both
cips007 is offline
post #11 of 13 (permalink) Old 01-02-2018, 10:21 AM Thread Starter
cips007's Avatar
Before I fit my new lever and pivot bolt,do you fit it dry or add a little grease?
cips007 is offline
post #12 of 13 (permalink) Old 01-02-2018, 10:39 AM
Grease. There's a channel in the bolt specifically for it
wibbly is offline
post #13 of 13 (permalink) Old 01-02-2018, 01:51 PM Thread Starter
cips007's Avatar
Ah got ya,wondered what that was for,thank you
cips007 is offline
