engine cutting out on track - need troubleshooing advice - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 8 (permalink) Old 03-17-2018, 10:46 PM Thread Starter
Noam Ben-Hamou's Avatar
Hi everyone. 2013 cbr600rr on the track I have very intermittent issue with engine cutting.
Happens about 3 times per track day at around 14,700rpm engine cuts off for about 0.1 seconds. Completely dies, and instantly goes back on. Obviously it's a bit scary because my front end gets loaded up instantly, and then a slight slip of the rear/clutch when engine kicks back on.
Another possibly related issue, every time I turn on the bike, and rev past 2000rpm for the first time only, I have the same hesitation engine cut. After that, I can free rev from idle no problem.
if I turn off bike, and turn it back on - again, once I rev up in the pits at around 2000rpm, engine cuts for 0.1 seconds and comes back on. It does that every time without fail.
Any idea of what I should troubleshoot? Crank position sensor? Rectifier? I already tried a new battery.
Thanks
Noam Ben-Hamou is offline
post #2 of 8 (permalink) Old 03-18-2018, 11:59 PM
blamrr's Avatar
Any mods? Pcv? Bazzaz?
Lightning Eggplant #314
blamrr is offline
post #3 of 8 (permalink) Old 03-19-2018, 01:34 AM
Ditto, mods?
No MIL code?
Maybe aftermarket fuel controller failing????
tary preisser is offline
post #4 of 8 (permalink) Old 03-20-2018, 01:42 AM Thread Starter
yes - bazzaz, but I tried another bazzaz unit today at the track, and same issue :(
No codes available for me from ecu because I don't have dash (using 2D dash)
post #5 of 8 (permalink) Old 03-20-2018, 01:50 AM
Can you get/borrow a Honda code reader tool/instrument?
post #6 of 8 (permalink) Old 03-20-2018, 08:11 AM
Crashchris's Avatar
quick shifter?
Crashchris is offline
post #7 of 8 (permalink) Old 03-20-2018, 10:44 AM Thread Starter
it's HRC ECU, so no dash output possible.
already unplugged quickshifter and didn't solve problem.
Thanks for brainstorming with me guys!
post #8 of 8 (permalink) Old 03-25-2018, 08:59 AM
BOTM Winner 07/16
rinonz's Avatar
Have you got enough fuel? I bang my head against the same issue for 2 seasons on the part of track. Turns out on uphill, with less than 5l of petrol there’s not enough fuel level for the pump and it cuts out.
rinonz is offline
The Following User Says Thank You to rinonz For This Useful Post:
tary preisser (03-25-2018)
