Anybody tried these fuel pumps? - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 8 (permalink) Old 01-06-2019, 12:47 PM Thread Starter
I need to replace my pump and found the company linked below. They have a lifetime warranty against failure but I still want to know from someone with experience how they perform and if they're a suitable replacement.
https://www.fuelperformance.co.uk/in...earch=Cbr600rr
Vortex is offline
post #2 of 8 (permalink) Old 01-06-2019, 01:15 PM
You need the assembly, not just the motor.
wibbly is offline
post #3 of 8 (permalink) Old 01-07-2019, 05:18 AM Thread Starter
Do you know if it's possible to get to and fix the regulator?
Vortex is offline
post #4 of 8 (permalink) Old 01-07-2019, 08:18 AM
You're much better off buying the entire fuel pump. Depending on what year you have they're like $50 on eBay. Just pay attention to mileage on the bike it came from (salvagers often state this).
I've replaced just the motor once. Won't do it again. It's a lot more work. And the fuel filter is in the housing (the thing that looks like a filter is just a strainer to catch the big chunks) so if your filter is clogged a new motor won't fix it. In fact it may kill the new one in short order.
Lifetime warranty sounds good until you realize you have to do all the labor to take it back out, clean it up and mail it back. It's like a guarantee on a puppy. Who ever actually returns one? Much less for a $75 item.
Bat-1 is offline
The Following User Says Thank You to Bat-1 For This Useful Post:
dixon cider (01-07-2019)
post #5 of 8 (permalink) Old 01-07-2019, 11:11 AM
the regulator is the little round piece at the bottom right of this pic. you can see it's part of the plastic casing, and has a return hole to let excess pressure back into the tank. you can't replace this part only.
there's no guarantee that this is the problem, but i suspect it probably is. you should flow test your fuel pump before ordering a new one, it's not hard to do.
but no, you cannot just replace that part, it's integral to the assembly.
wibbly is offline
post #6 of 8 (permalink) Old 01-07-2019, 03:28 PM Thread Starter
Bat-1, thank you! I didn't think they'd be so cheap and I'll definitely look into that.
Wibbly thanks for sharing you knowledge again!
Vortex is offline
post #7 of 8 (permalink) Old 01-07-2019, 08:30 PM
Lifetime Premium
dixon cider's Avatar
I got two used ones off Ebay last year. I did a bench flow test to test mine at 38k miles vs. both of the used ones that were at about 10k miles. The used ones both flowed better than my original. I took them all apart and cleaned them out and used the best pieces from all three and had good luck with the rebuilt one.
First time rider over 40. Finally made it!
dixon cider is offline
post #8 of 8 (permalink) Old 05-03-2019, 10:03 AM
Daren Mitchell's Avatar
Did you buy fuel pump?
Daren Mitchell is offline
