Top fuel rail? - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 17 (permalink) Old 02-17-2019, 07:37 PM Thread Starter
Top fuel rail?
Can anyone tell me why my top fuel injectors are not working?.......i changed out the fuel pump and the battery and the voltage regulator but nothing has changed.....if anyone could help me i really would appreciate it
Deron92 is offline
post #2 of 17 (permalink) Old 02-18-2019, 05:06 AM
Ruby Racing's Avatar
Is the fuel pump fuse blown? It's a 20amp under the riders seat, behind the battery.
Have you reconnected all wiring when rebuilding?
Ruby Racing is offline
post #3 of 17 (permalink) Old 02-18-2019, 10:13 AM Thread Starter
Yeah the fuel pump fuse is still good and wiring is all connected but no fuel is coming out the top at all
Deron92 is offline
post #4 of 17 (permalink) Old 02-18-2019, 02:25 PM
The upper rail isn't on all the time. What conditions are you testing it under
wibbly is offline
post #5 of 17 (permalink) Old 02-18-2019, 03:59 PM Thread Starter
When i rev the engine it will not go passed 5.5k so i opened the air box to watch the injectors but they never come on......when i ride the bike it starts fine and runs fine until i give it gas and try to accelerate but it doesnt.......i have a new fuel pump, voltage regulator and battery
Deron92 is offline
post #6 of 17 (permalink) Old 02-18-2019, 08:38 PM
Was there a service done recently? Did you install a manual cct or anything?
If the bike won't rev past 5.5k it's not the secondary rail causing trouble.
wibbly is offline
post #7 of 17 (permalink) Old 02-18-2019, 09:19 PM Thread Starter
No i haven't had the cct checked but iv been working on the bike for 6 months now and this is the issue i ran into now......if it wont rev passed 5.5k what is causing it not to accelerate right? Could it be the ground box?
Deron92 is offline
post #8 of 17 (permalink) Old 02-18-2019, 10:29 PM
It could be out of time.
Did you do a valve adjustment?
wibbly is offline
post #9 of 17 (permalink) Old 02-18-2019, 11:02 PM Thread Starter
No valve adjustments but could the throttle cable cause the problem?
Deron92 is offline
post #10 of 17 (permalink) Old 02-19-2019, 12:39 AM
If the throttle was stuck you'd know about it right away.
wibbly is offline
post #11 of 17 (permalink) Old 02-19-2019, 09:21 AM Thread Starter
What should i check out
Deron92 is offline
post #12 of 17 (permalink) Old 02-19-2019, 02:09 PM
What did you do to it in the last 6 months. Chances are you messed something up.
wibbly is offline
post #13 of 17 (permalink) Old 02-19-2019, 02:54 PM Thread Starter
I havent done much just wire the blinkers and taillights then the fuel pump and voltage regulator......but its been doing this since i bought the bike
Deron92 is offline
post #14 of 17 (permalink) Old 02-19-2019, 03:58 PM
And no matter what you do it will never go over 5500?
wibbly is offline
post #15 of 17 (permalink) Old 02-19-2019, 04:28 PM Thread Starter
It just stays below 5.5k sometimes it will go to 10k but it has trouble.......could the top injectors all be bad? If i buy a new fuel rail and change it i wonder if that would fix it
Deron92 is offline
post #16 of 17 (permalink) Old 02-19-2019, 06:57 PM
It could be a bunch of things. But buying parts on a hunch will empty your wallet before it fixes your bike.
wibbly is offline
post #17 of 17 (permalink) Old 02-19-2019, 07:14 PM Thread Starter
Yeah thats true.....could my injectors not be getting power? What else would cause the fuel system to stop?
Deron92 is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Upper Fuel Rail wont Spray bmac7599 Troubleshooting 78 06-29-2018 03:04 PM
06 Won't start. Has spark, and fuel to rail. cajun 03-06 RR Modifications 18 03-17-2016 11:14 PM
Removing fuel line from fuel rail mran556 Engine Tech 3 03-30-2014 07:48 PM
Secondary fuel rail leak raptor Troubleshooting 8 12-02-2011 01:52 PM
WTB: '05 lower fuel rail alecracing Wanted 0 04-02-2007 10:37 AM
