Bike won’t start. won’t even prime - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 29 (permalink) Old 03-22-2019, 04:00 PM Thread Starter
CeeBeeRR's Avatar
i changed the oil after winterizing it. woke up trying to go for a ride didn’t want to prime and after so many tries it worked and worked fine throughout the whole day and here we go again came home for 30 min and didn’t want to start once again. i figure out when i turn off and on fast it will pump but sometimes won’t start
CeeBeeRR is offline
post #2 of 29 (permalink) Old 03-22-2019, 08:21 PM
Try turning the ignition on and off several times before cranking to let the pump prime. If this works, its fuel related. Either clogged filter or pump going bad etc.
'06 F4i- Yoshimura RS-3C, Racetech springs and valves, Ohlin's rear shock, steel brake lines, 520 conversion. 87k miles and counting.....
'08 600RR- Stripped trackbike. CRG shorty brake lever, goodridge front brake lines
'15 1000RR- weekend toy
------Disclaimer: I can't spell------
bored&stroked is offline
post #3 of 29 (permalink) Old 03-23-2019, 12:00 AM
battery in good condition?
tary preisser is offline
post #4 of 29 (permalink) Old 03-23-2019, 12:16 AM Thread Starter
CeeBeeRR's Avatar
the pump won’t prime. sometime it will sometime it won’t. if i flick the ignition off and on real fast it will work.
CeeBeeRR is offline
post #5 of 29 (permalink) Old 03-23-2019, 12:18 AM Thread Starter
CeeBeeRR's Avatar
about year old. have it on battery tender throu the winter. like i said if i turn the ignition off and on real fast it will prime some time i works perfectly fine sometime it won’t prime u less i flick fast. once it runs it runs perfect pretty much
CeeBeeRR is offline
post #6 of 29 (permalink) Old 03-23-2019, 12:21 AM
does your bike have HISS?
wibbly is offline
post #7 of 29 (permalink) Old 03-23-2019, 12:28 AM Thread Starter
CeeBeeRR's Avatar
not sure what does that mean? check engine light or like flashing? is there a way i can post videos here? but no lights nothing just won’t prime. i have a decent video but can upload it here.
CeeBeeRR is offline
post #8 of 29 (permalink) Old 03-23-2019, 12:31 AM
no hiss is the honda security system.
wibbly is offline
post #9 of 29 (permalink) Old 03-23-2019, 12:38 AM Thread Starter
CeeBeeRR's Avatar
nope. don’t have it
CeeBeeRR is offline
post #10 of 29 (permalink) Old 03-23-2019, 12:47 AM Thread Starter
CeeBeeRR's Avatar
https://vimeo.com/326007983/comments
and besides those issues. runs perfect and it will sometimes prime normally 10/10 times
CeeBeeRR is offline
post #11 of 29 (permalink) Old 03-23-2019, 01:58 AM
when it doesn't prime, does the FI and HESD light come on?
turning your key quickly has nothing to do with your problem, you're just looking too hard for patterns.
wibbly is offline
post #12 of 29 (permalink) Old 03-23-2019, 11:24 AM Thread Starter
CeeBeeRR's Avatar
no it doesn’t.
sucker is annoying
CeeBeeRR is offline
post #13 of 29 (permalink) Old 03-23-2019, 11:37 AM
Then it's your kill switch, bank angle sensor, or engine stop relay.
I'm pretty sure the kill switch is white/yellow and black in the connector. Just put a wire jumper in the back of the connector and see if the problem persists
wibbly is offline
post #14 of 29 (permalink) Old 03-23-2019, 12:21 PM Thread Starter
CeeBeeRR's Avatar
nope. nothing
CeeBeeRR is offline
post #15 of 29 (permalink) Old 03-23-2019, 12:26 PM
jump out the kill switch as i told you to do in my last post. it's either that, the BAS, or the relay. or some issue in that circuit.
wibbly is offline
post #16 of 29 (permalink) Old 03-23-2019, 03:42 PM Thread Starter
CeeBeeRR's Avatar
can you explain it? i’m not that good with figuring out issues with bikes.i just know how to ride them haha.
CeeBeeRR is offline
post #17 of 29 (permalink) Old 03-23-2019, 03:45 PM Thread Starter
CeeBeeRR's Avatar
i didn’t see this post. so inside the kill switch i’ll find the wires?
CeeBeeRR is offline
post #18 of 29 (permalink) Old 03-23-2019, 05:04 PM
no, in the connector where the kill switch pod plugs in
wibbly is offline
post #19 of 29 (permalink) Old 03-26-2019, 12:14 AM Thread Starter
CeeBeeRR's Avatar
is there a plug in behind the kill switch?
CeeBeeRR is offline
post #20 of 29 (permalink) Old 03-26-2019, 12:36 AM
it's below the tank cover.
wibbly is offline
post #21 of 29 (permalink) Old 03-26-2019, 03:01 PM Thread Starter
CeeBeeRR's Avatar
i’ll look at it when i get back. is it hard to get too? i still don’t understand the wire you talking about? can you howmmena pic or something?
CeeBeeRR is offline
post #22 of 29 (permalink) Old 03-26-2019, 03:06 PM Thread Starter
CeeBeeRR's Avatar
i just don’t understand what a wire jumper is. i’m a bit confused honestly on what to do. like take out the plug and what do i do with the wire? on the plug? i’m so lost. if you can explain in better tho hahaha plzzzz
CeeBeeRR is offline
post #23 of 29 (permalink) Old 03-26-2019, 03:32 PM
Connect the white yellow to the black with a piece of wire
wibbly is offline
post #24 of 29 (permalink) Old 03-26-2019, 10:28 PM
SloKnt's Avatar
Had same issue, was broken wire b/w hiss and ignition
Slow and Scared
SloKnt is offline
post #25 of 29 (permalink) Old 03-27-2019, 03:53 PM Thread Starter
CeeBeeRR's Avatar
it hasn’t been doing it since i put.m new gas in but i turned it on this morning when it started it had a split second like it was going to die but nothing and i let it warm up and kinda feels sounds different but it could be me cause im like looking for a sound or problem haha also last two days i turned the bike on to let it run and 1 gas bar already got burned. wonder if i’m burning gas fast?
here is the video when i start it. i’m lost a cold start tomorrow kinda sounds like something from gas tank idk anymore
CeeBeeRR is offline
post #26 of 29 (permalink) Old 03-27-2019, 03:55 PM Thread Starter
CeeBeeRR's Avatar
did it look like that or you dogged in to see? it turns on now but kinda a weird start when it goes. especially on cold starts. i’m going to ride today see what happens
CeeBeeRR is offline
post #27 of 29 (permalink) Old 03-28-2019, 12:28 AM
if you aren't going to at least humor me by doing what i'm trying to walk you through, then i can't help you
hope you figure it out by making videos and doing nothing.
wibbly is offline
post #28 of 29 (permalink) Old 03-29-2019, 09:36 AM
doitmanny's Avatar
start with a full charged battery, check kill switch, try to move wires around just to make sure they are fine and nothing its broken, then fuel pump relay, and bank sensor, make sure you have gas, that you FI its showing on the cluster, check fuses box, grown for poor connection, try to apply 8.6-12.4V to fuel pump on her own see if this work if does, then test fuel pump wires for signal, and trace your problem back from there.
Them: You think you Funny?
Me: No, I'm adorable.
doitmanny is offline
post #29 of 29 (permalink) Old 04-01-2019, 09:30 PM
SloKnt's Avatar
Originally Posted by CeeBeeRR View Post
did it look like that or you dogged in to see? it turns on now but kinda a weird start when it goes. especially on cold starts. iím going to ride today see what happens
Mechanic opened the shroud cos thatís where the Honda diagnosis tool thing told him it traced it to.
As it bends around the bracket it broke, sometimes it would prime sometimes no.
Slow and Scared
SloKnt is offline
Similar Threads
Thread Thread Starter Forum Replies Last Post
Will 06’ fairings fit my 03’?? Tad Taggart New Members 0 06-02-2018 11:22 AM
Fuel pump won’t prime after bike failure Thewifesbike General Discussion 55 04-25-2018 11:12 AM
04' won't start , not even push start tonygosafar Troubleshooting 6 07-22-2015 12:45 PM
Bike won't start, fuel pump won't prime. AGAIN! WTFGO Troubleshooting 30 07-26-2013 05:11 PM
Bike won't start, prime, or light up. Agent54 Troubleshooting 11 08-08-2007 11:55 PM
