2003 600rr no crank (kill switch issues?) - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 7 (permalink) Old 05-13-2019, 12:42 AM Thread Starter
Purchased 2003 600rr couple weeks ago with a half broken kill switch button (worked perfectly fine but wanted to replace anyways). Purchased a good used kill switch unit and tried to replace today. I was unsuccessful taking off throttle tube, didn't have enough time, had to get ready for mothers day. So decided to put everything back together and figure it out on my day off. After getting it back together I turned on engine but it cranked slower than usual but started, i shut her off and did this about 3-4 times. All of a sudden it just stopped cranking. When i press start button the headlight just turns off and back on. I also dont hear the fuel pump prime anymore.
Any ideas what could have gone wrong ?
licketysplit is offline
post #2 of 7 (permalink) Old 05-13-2019, 12:49 AM
if the pump doesn't prime the kill switch isn't satisfied.
the start button shuts off the headlights, that's normal.
wibbly is offline
post #3 of 7 (permalink) Old 05-13-2019, 01:00 AM Thread Starter
ok kill switch is faulty.
post #4 of 7 (permalink) Old 05-13-2019, 01:18 AM
Probably..
wibbly is offline
post #5 of 7 (permalink) Old 05-13-2019, 09:35 AM
indfireblade's Avatar
Check all the solder connections on the switch and also take it apart and clean the contacts real good. Then try again
indfireblade is offline
post #6 of 7 (permalink) Old 05-15-2019, 12:50 AM Thread Starter
replaced kill switch unit, started right up. thanks!
post #7 of 7 (permalink) Old 05-16-2019, 09:23 AM
Good Deal!
Similar Threads
Thread Thread Starter Forum Replies Last Post
HELP: Installed LP Integrated TL now NO Headlight & High Beam **Kill switch wire ** omie_cbr Troubleshooting 8 06-05-2014 01:54 AM
Use kill switch as ignition switch? champ955 07-13 RR Modifications 8 02-14-2012 10:13 PM
No crank no start on my 05 Tipys Troubleshooting 11 06-11-2009 04:40 PM
Kill Switch Upgrade 06 to an 07 switch. Need Wiring Help tidrow55 03-06 RR Modifications 3 10-22-2008 11:46 PM
Zuki Squids...no no no no no. Meddiepie954rr Off Topic & Flame Thrower 6 11-05-2004 12:31 PM
