Oil Level - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 5 (permalink) Old 05-28-2019, 08:04 AM Thread Starter
Oil Level
I had the bike on a paddock stand the other day to check the oil level, I noticed the level drops when the bike is running. Where should the oil level by running vs standing?
Cheers
Chisel is offline
post #2 of 5 (permalink) Old 05-28-2019, 10:39 AM
you don't check the oil level when it's running. that's irrelevant.
wibbly is online now
tary preisser (05-29-2019)
post #3 of 5 (permalink) Old 05-28-2019, 05:33 PM
cips007's Avatar
I Warm the bike up to normal operating temp/or after a ride,let it stand for 5 mins with engine off to let the oil settle while warm. Stand the bike up level not using a paddock stand etc (easier if you have someone to hold the bike level for you) then check the oil is between the lower and upper marks in the sight glass.
I always check it this way and not when the engine/oil is cold 👍
cips007 is offline
post #4 of 5 (permalink) Old 05-28-2019, 06:44 PM
Checking cold is fine, all the oil is drained into the sump by then. Warming up and waiting 5min is the way the manual tells you to do it. Don't check running.
'06 F4i- Yoshimura RS-3C, Racetech springs and valves, Ohlin's rear shock, steel brake lines, 520 conversion. 87k miles and counting.....
'08 600RR- Stripped trackbike. CRG shorty brake lever, goodridge front brake lines
'15 1000RR- weekend toy
------Disclaimer: I can't spell------
bored&stroked is offline
The Following User Says Thank You to bored&stroked For This Useful Post:
post #5 of 5 (permalink) Old 05-29-2019, 12:17 AM
bike on f/r stands, I check for oil level to be in between slightly above widest upper part and narrow neck of sight glass.
done when cold.
If level down in narrow neck I add 100 cc, but I usually do an oil change instead, it's usually about time.
tary preisser is offline
