2007 CBR 600rr issue? - 600RR.net
General Discussion General Honda CBR600RR Motorcycle Talk - please place mods, tech tips and off topic threads in the correct forums.
post #1 of 5 (permalink) Old 05-29-2019, 11:52 AM Thread Starter
Hoonda600's Avatar
The other day when I was riding I was coming to a stop and had the clutch all the way in and when Iíd rev the bike up a bit with the clutch in a would feel a clunk and it felt like the bike was jerking forward a bit. Seems to only happen sometimes, what can this be? Also when I let off the throttle and rpms drop down to 5-2k I hear a ticking sound from the front end of bike. Pretty sure I hear the same tick as I speed up but the faster I go it turns into a whine.
Sent from my iPhone using Tapatalk
Hoonda600 is offline
post #2 of 5 (permalink) Old 05-29-2019, 02:33 PM
sounds like you're getting "false neutral" in between gears.
Try shifting more positively, and be careful to rev match.....
For ticking, put bike up on stands and spin wheel, see if you can ID source of clicking?
tary preisser is offline
post #3 of 5 (permalink) Old 05-29-2019, 02:35 PM Thread Starter
Hoonda600's Avatar
I always shift good and down shift and rev match and it always feels smooth. Itís just when Iím rolling with clutch disengaged
post #4 of 5 (permalink) Old 06-28-2019, 09:08 AM
chriscook5636's Avatar
Make sure your clutch lever has about a half inch of free play, if your cable is adjusted properly your clutch plates may be sticking, do you do wheelies or clutch ups at all ? Or did the previous owner? Aluminum clutch basket ears get clutch plate indents over time causing the plates to stick. If or when you replace the clutch take the basket off and use some really smooth sandpaper and sand the basket ears flush and smooth getting rid of the indents on all of the ears. Look at the photo for an idea of what I’m talking about Click image for larger version
chris cook
chriscook5636 is offline
post #5 of 5 (permalink) Old 06-30-2019, 12:40 AM Thread Starter
Hoonda600's Avatar
Originally Posted by chriscook5636 View Post
Make sure your clutch lever has about a half inch of free play, if your cable is adjusted properly your clutch plates may be sticking, do you do wheelies or clutch ups at all ? Or did the previous owner? Aluminum clutch basket ears get clutch plate indents over time causing the plates to stick. If or when you replace the clutch take the basket off and use some really smooth sandpaper and sand the basket ears flush and smooth getting rid of the indents on all of the ears. Look at the photo for an idea of what Iím talking about Attachment 201239
No wheelies and bike only had 20k. Seems to only happen sometimes and it doesnít affect shifting at all and not 100% sure but seems to only happen at slower speeds like 5-20kmh
