speed wobble - 600RR.net
Trackdays Privateers and Professionals
post #1 of 24 (permalink) Old 01-13-2006, 10:44 PM Thread Starter
speed wobble
03 RR.
Do any of you guys get a speed wobble? Atleast 110+ it starts to kick in. I know it's not meant to so I'm just curious.
600hcrr is offline
post #2 of 24 (permalink) Old 01-13-2006, 10:57 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
how bad of a wobble we talkin bout?? i have felt a slight wobble goin 115+. i dont go that fast anymore. im a law abiding citizen plus my life is more important. keep the speeds at the tracks. jus did it to see what my bike has.
anywho....i think its normal for a little wobble. you gotta take into consideration the condition of the roads its not smooth, the wind and other factors i cant think of right now.
SLAPS808 is offline
post #3 of 24 (permalink) Old 01-13-2006, 11:00 PM
Post Whore Extraordinaire
snikwad's Avatar
Images: 15
Feedback Score: 16 reviews
never had one.
i try my very very best not to go that fast on the streets anymore too.
it was working before i left, hopefully i dont have to get another ticket to stay legal.
No more mod listing, shits is STILL too long
03 600RR > 04 1000RR > 06 R6V > 05 600RR > 06 R1 > 09 1000RR > 10 RSV4R :gun:
snikwad is offline
post #4 of 24 (permalink) Old 01-14-2006, 12:09 AM Thread Starter
The wobble is somewhat bad, I don't think I'd fall though. A little wobble is normal, but it never did it like this before. I've checked pressure.
the wobbles definitely dangerous. And it's consistent doesn't matter what road condition. Maybe my tires need balancing..?
600hcrr is offline
post #5 of 24 (permalink) Old 01-14-2006, 02:59 AM
snikwad's Avatar
Images: 15
get a steering damper. and rebalance your wheels.
If that doesnt fix it, it may be suspension related.
snikwad is offline
post #6 of 24 (permalink) Old 01-14-2006, 04:05 AM
SLAPS808's Avatar
yah i dont experience that. you can try re balancing the wheel and see if it goes away. best bet is to have it checked out. im still learnin this game. so i couldnt tell ya what the problem is or could be. be patient, im sure someone on this board can offer you some good suggestions/advice.
jus dont go that fast is all i can say. unless its doin the wobble at normal freeway speeds to. then you really should have it checked. gl mang
SLAPS808 is offline
post #7 of 24 (permalink) Old 01-14-2006, 10:13 AM
tyrebuster's Avatar
I would say that could be a few things. Tires, bearings, suspension could be a few
Mototire, Arata full system, PCIII, Stomp Grip, DID ERV3, Michelin, Racers Edge, Goodrich lines, Run Gp, Veserah, Vortex rear set w/ GP shift, Vortex fairing stay, clipons, & sprockets, Woodcraft case covers & frame sliders, GPR stabilizer, R-R Racing subframe, Speedcell SS race battery, Elka shock, Cheetah body work.
#57 CCS SW
tyrebuster is offline
post #8 of 24 (permalink) Old 01-14-2006, 11:27 AM
id say suspension, under a different set up that i have now, i used to get a slight wobble under hard excelleration and turning, kind of like turn 2 at jennings, WOT and turn at the sametime... now i set up the suspension so the front and rear compress and rebound at the same time, so it eliminated that kind of wobble, maybe you can try that.
MannyMalice is offline
post #9 of 24 (permalink) Old 01-14-2006, 12:00 PM
LonelyRR's Avatar
Images: 241
Originally Posted by snikwad
never had one.
+1 shouldn't be going that fast on streets. High speed wobble on the street is bad.
LonelyRR is offline
post #10 of 24 (permalink) Old 01-14-2006, 12:30 PM
Check your fork seals. If its an 03 and you avhe ridden it hard, or it goes through some drastic temp changes, your seals can get worn out over time, jsut the first thing that came to mind here. A good indication is check the bottom of the forks and see it you can see any residue on your forks perhaps.. it also could be bearings too.. Have you ever fiddled witht eh clickers on your forks? make sure you have the same number of clicks on your forks too.. Just a few simple things to think about
bhawkce is offline
post #11 of 24 (permalink) Old 01-14-2006, 01:13 PM
Sodamninsane's Avatar
Images: 15
check your bearings... how many miles you got?? if the steering stem nut came loose, that'll wobble for sure... and it'll make the bike really unpredictable. torque that... then check the axle bearings and tire pressures for each end of the bike... Sound like you're just beginning to wear them out... also, if you let go of the grips at like 30 or 40 does it start to head shake on you??? that's probably the steering stem of the front axle... otherwise if it seems more like one end of the bike is jumping a little bit thats probably a wheel thats out of balance..
Sodamninsane is offline
post #12 of 24 (permalink) Old 01-14-2006, 03:57 PM
Images: 9
do a search on hi speed vibration, I had one...
powerranger is offline
post #13 of 24 (permalink) Old 01-14-2006, 07:07 PM
if your on the street you shouldnt be going 110 in the first place. Thats the reason normal people hate bikes on the streets and try to throw basketballs at them. THats the reason i stay on the track full time now
fatboy122 is offline
post #14 of 24 (permalink) Old 01-14-2006, 11:03 PM Thread Starter
Thanks for the advice fellas, I'll check those things.
And I never said it was on the streets.
600hcrr is offline
post #15 of 24 (permalink) Old 01-15-2006, 01:52 AM
snikwad's Avatar
Images: 15
true that, you never did say that.
snikwad is offline
post #16 of 24 (permalink) Old 01-15-2006, 08:32 AM
Ummmmmmmm...............
NO! A "wobble" is NOT normal.
It can mean many different things..........
1. You are holding the clip on's tighter and tighter the faster you go, this means that if your front wheel hits a bump or object in the road your tight grip is not letting that energy transfer anywhere but back to the tire and cuasing a tank slapper. These can cause the bike to wreck and kill you.
2. You have an unbalanced tire...........get it balanced.
3. You have something wrong with the alignment of your forks or something else.
The easy fix here would be to get a damper; but learning to ease off of those clip ons (if that is the culprit here) would be the better option than just throwing money at the problem and learning how to ride correctly.
sargeek1975 is offline
post #17 of 24 (permalink) Old 01-17-2006, 12:42 AM
Images: 3
What about a low speed wobble. Mine gives a little wobble at around 5 - 10 mph then disappears. Any thoughts?
Trimar666 is offline
post #18 of 24 (permalink) Old 01-17-2006, 06:06 AM
Wheel balanced?
post #19 of 24 (permalink) Old 01-17-2006, 07:57 AM
NewRedRider's Avatar
Images: 24
I whole heartedly agree with Sarge! NEVER recommend someone get a steering damper when they have an obvious mechanical problem. Fix the problem. Have GMD take a look at the alignment.
Have you dropped the front or raised the rear?
NewRedRider is offline
post #20 of 24 (permalink) Old 01-17-2006, 08:45 AM
Just a thought but if you're accelerating hard at that speed you might be too far back on the bike (get your chin over the triple.) I've found on the track that the cbr front end gets light at the top of just about any gear if you're too far back in your tuck. Just my 0.02
cyclescientific is offline
post #21 of 24 (permalink) Old 01-17-2006, 09:09 AM
snikwad's Avatar
Images: 15
yeah that true, ive felt a little shake doing that on on ramps.
but i dont know, wasnt he on a straight just nailing it. i dont think our bike does that on straights
snikwad is offline
post #22 of 24 (permalink) Old 01-17-2006, 09:18 AM
My first few times on the track I'd get really light in a straight and I'm pretty heavy (~200lbs) before I learned to sit further forward but I guess who knows. I was also thinking that a bad suspension set-up could cause this. Just a guess but if the front end was set too hard it might have a tendency to 'float' a little. Maybe an adjustment is in order?
post #23 of 24 (permalink) Old 01-17-2006, 09:22 AM
snikwad's Avatar
Images: 15
i guess im too light to affect the bike then. lol.
snikwad is offline
post #24 of 24 (permalink) Old 01-17-2006, 09:32 AM
lol... and I'm too fat for the poor thing. It just sputters and back-fires as I go around the track.
You may post new threads
You may post replies
