fuel types - 600RR.net
post #1 of 30 (permalink) Old 05-26-2009, 08:36 AM Thread Starter
fuel types
just curious as to see what kind of gas people use. any mixes or whatever
SleepWellInFire is offline
post #2 of 30 (permalink) Old 05-30-2009, 09:15 AM
91 octane :)
Ayres_08 is offline
post #3 of 30 (permalink) Old 05-30-2009, 11:37 AM
tenjin's Avatar
use what ever your book tells you to use
03-06 sould be 87, 07+ is 91
if your not getting pinging, you dont need any more than what the book says, and more would be wastfull.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #4 of 30 (permalink) Old 06-01-2009, 04:25 PM
Chip O's Avatar
93 here...
Chip O is offline
post #5 of 30 (permalink) Old 06-01-2009, 05:18 PM
chipmunkofdoom2's Avatar
Anything above your recommended octane in the manual is a waste.
Higher octane is difficult to burn, and it's great for high compression motors, but especially on the 03-06, you don't need it. The newer RRs need higher octane, but anything higher that the recommend octane is a waste.
Squid test:
So far, 13109 people (including you) have responded to this Squid Test Survey and have been tabulated.
Of those responses, the average grade is 53. Your grade was 82 (from 0 to 100)
A higher grade indicates a stronger sense of common decency, and a lower grade is an indication of conspicuous squidliness and general disregard for civilized society. Your score indicates that you are a fairly responsible motorcyclist but a bit of a wise-ass.
Hahaha.
chipmunkofdoom2 is offline
post #6 of 30 (permalink) Old 06-01-2009, 05:29 PM
i put 89 in mine the other night. ran half of it out pretty quick. i was wondering why it went faster then normal =/ ill stick with 87 then
DANGITSBRANDON is offline
post #7 of 30 (permalink) Old 06-01-2009, 05:30 PM
stevewfl's Avatar
2008 R1 YAMAHA in pornstar nipple red
2007 CBR600RR
stevewfl is offline
post #8 of 30 (permalink) Old 06-01-2009, 05:31 PM
stevewfl's Avatar
2007 CBR600RR
stevewfl is offline
post #9 of 30 (permalink) Old 06-01-2009, 05:44 PM
Devigonz's Avatar
Theres this one guy that put NOS in his gastank, woked out pretty well for him.
Originally Posted by PROTOTYPE View Post
Hornets and Wasps like to attack loud vibrating things close to their nests ... like lawnmowers, or dildos, or epileptics.
So NEVER operate a lawnmower, a motorcycle, and a dildo at the same time if you are an epileptic and near a wasps nest... don't even think of it.
Devigonz is offline
post #10 of 30 (permalink) Old 06-02-2009, 06:40 PM
Chip O's Avatar
[quote=chipmunkofdoom2;2370010]Anything above your recommended octane in the manual is a waste. quote]
True, but you have to remember that:
1. The manual says "86 OR HIGHER" octane
2. 03-06 have 12.5:1 compression. (there is a general rule, which I suspect may be true, that says if you move your compression decimal point over 1 digit to the right, you get your optimal octane rating, but i'm not sure if you can apply this to high revving bikes)
3. Our engines rotate at such high speeds (internally) that you're prolly not going to actually hear any detonation, especially when you also factor in the loudness of the bike itself. you could be detonating and not even know it.
I've been struggling with the octane question for a while now and I can't seem to find a definitive answer, but wouldn't you rather foul your plugs over a long period of time that destroy your internals?
your only saving pennies at the pump anyway.
Chip O is offline
post #11 of 30 (permalink) Old 06-02-2009, 06:44 PM
tenjin's Avatar
you WILL hear the pinging, its very decernable
and pennies?
lets see, 50 cents a tank, a tank every other day for me, thats 2 dollars a week? 52 weeks in a year, thats 104 dollars a year, or about 500 dollars over what the average person might keep a bike .... thats not bad
and as far as your rule of thumb, i have neard heard such a thing, and ive been building race motors for 10 years.
DDM 55w 7k HID
Sliders
R&G Bar Ends
JPR Shorty levers
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #12 of 30 (permalink) Old 06-02-2009, 06:50 PM
1ofakindRR's Avatar
and pennies?
Yeah guys. Just try it. I did and I noticed no difference when using 87 rather than 91. Still rides like she has. And they only call it V=Power because of it's rating, not because it has additives because they all do. Shell gas is the cleanest around whether you use 93 or 85. But back to topic, my bike has a slight tick to it as im sure everybodies does and it'll do it with any grade you use. I'm probably the highest in altitude than anybody here so my bike starves for air anyways but the change in grade of fuel did nothing but save me $$$$$$$$ :icon_stud
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
post #13 of 30 (permalink) Old 06-03-2009, 10:42 PM
Dr. GoFast's Avatar
google "top tier gas" and you'll see why i only use chevron and shell. mobil sometimes, but only out of convenience.
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #14 of 30 (permalink) Old 06-04-2009, 04:09 PM
Chip O's Avatar
and pennies?
I'm simply saying that the risk of fouling plugs is more acceptable than the risk of ruining internals. and the rule of thumb i speak of came from a proffesor of automotive engineering at WWU, but I'm sure there are many more factors to consider when using said rule (I.E. rotating mass/speed/induction/timing/etc.)
Chip O is offline
post #15 of 30 (permalink) Old 06-04-2009, 06:42 PM
davethebossman's Avatar
I agree with you, chipottley.
Respectfully, tenjin, you're wrong. This isn't a diesel engine. You won't hear pinging since there are deliberate parts in the bike to silence engine noises. Plus gas doesn't have the explosive power to "ping" as people on this site are attempting to explain. You won't hear pinging. And it's a matter of engine kinetics that makes chipottley right.
Dave
davethebossman is offline
post #16 of 30 (permalink) Old 06-09-2009, 06:43 AM
deputy963's Avatar
I haven't experienced knock on a bike, but I can feel-hear it in a car. Sounds like a box of marbles in a trash can! The CBR has a knock sensor, which should retard timing when knock occurs, but I bet I would feel/hear it before the timing was retarded.
Higher octane fuel has a higher ignition point and burns slower than fuel of a lower octane. The reason higher octane fuel is recommended for engines with higher compression is hot spots and compression temp. As the engine runs edges of parts (raises on piston, valve edges, etc) become hot and retain the heat, which when combined with the compression can ignite the fuel prior to the spark plug firing. Diesels actually run without spark plugs (after warming by glow plug) by compressing the fuel to the point of ignition.
Using fuel of a higher octane than required can actually hurt performance, as higher octane fuel burns slower and may not be completely burnt by the end of the power stroke.
Just my .02
deputy963 is offline
post #17 of 30 (permalink) Old 06-11-2009, 09:19 PM
Chip O's Avatar
I wasn't aware of our bikes coming w/a knock sensor. that's good to know, but i bet none of us would be able to hear any detonation 'cause of part sizes, rotational speed, insulation dynamics, etc.
Just my .02
Understandable, but with close to 100rwhp on our bikes, doesn't it make sense to run the risk of losing tiny ammounts of fuel and power (and possibly foul plugs over a relatively long time) rather than risk ruining internals?
Chip O is offline
post #18 of 30 (permalink) Old 06-11-2009, 09:33 PM
Originally Posted by stevewfl View Post
+1 I try to only use shell
100proofrider is offline
post #19 of 30 (permalink) Old 06-11-2009, 10:09 PM
This has all been extremely enlightening. But have we come to a consensus? I was never worried about this until just now. A recap maybe? Or Pro/Con of octane levels might serve us well. I am sure a ton of people would benefit from such a thing!
'08 CBR600RR
Power is Nothing without Control.
SRaiders3102 is offline
post #20 of 30 (permalink) Old 06-12-2009, 09:55 AM
deputy963's Avatar
Since the engine is bolted directly to the frame I would bet you could feel it in the seat of your pants. Detonation is also very noticeable from a performance standpoint; i.e., you'll know it if it is anything but the most minute pre-ignition.
Detonation is more likely at lower RPM under load because the fuel has more time exposed, so really your bike is more likely to be making 20 or 30 HP when it happens.
What we need is someone with access to a dyno to do runs on a stock bike with 87, 89, and 91 octane and post the results. That would put an end to this and probably bring world peace!
post #21 of 30 (permalink) Old 06-12-2009, 10:00 AM
Since when has ANYTHING recommended by Honda and the manual ruined a Honda motorcycle?
Squid test:
Hahaha.
post #22 of 30 (permalink) Old 06-12-2009, 12:34 PM
Chip O's Avatar
I think that's a GREAT idea!!! I wish I could help.
That's not really fair to Honda, since they can't recomend a fuel that isn't available in all states/countries. That's why the Shop Manual says 86 or higher.
What we're trying to figure out, is what fuel octane is optimal, not just acceptable.
Chip O is offline
post #23 of 30 (permalink) Old 06-13-2009, 12:47 AM
deputy963's Avatar
That's also something to keep in mind. Honda has to cover all the bases (availability and measurement method), so their printed manual is probably a few point high to prevent lawsuits.
post #24 of 30 (permalink) Old 06-13-2009, 01:27 AM
bwolfe84's Avatar
Feedback Score: 5 reviews
i have only used 91 octane chevron in my bike.
Honda 600RR RED (Julia)
"Ambition is just a poor excuse for people to not have enough sense to be lazy..."
bwolfe84 is offline
post #25 of 30 (permalink) Old 06-13-2009, 01:30 AM
nothing lower than 91
madnessracing is offline
post #26 of 30 (permalink) Old 06-13-2009, 01:30 AM
I would love to see some dyno numbers using different octane ratings. If anyone has access to a dyno that would be awesome!
Peanutjuice is offline
post #27 of 30 (permalink) Old 06-23-2009, 03:16 AM
ZachRR's Avatar
I always run 91 in my bike. But tonight i wanted to experiment so i went with 100 octane race fuel. Didn't notice any difference. Seemed the exact same to me.
Faster, faster, faster...until the thrill of speed overcomes the fear of death.
4 wheels move the body, 2 wheels move the soul.
Mods:::::
Custom dyno tune
Two bro's carbon fiber slip-on
K&N air filter
Power Commander V
520 chain conversion -1/+2
Fender eliminator
Integrated tail light
Flush mount turn signals
Puig double bubble windscreen (Red)
CBR tank protector
CBR grips
Padded rider seat
RR etched passenger seat
All that rollin' on dunlop Q2's
ZachRR is offline
post #28 of 30 (permalink) Old 06-23-2009, 03:03 PM
stormy's Avatar
Feedback Score: 11 reviews
ignoring the hype the ferrari uses shell in there f1 cars I can say that on the dyno 89 shell used to be hands down the best when tuning. However where there v-power 91 came out that has a slight margin over it. Some people call the gains noise but on a motorcycle that noise is worth chasing.
stormy is offline
post #29 of 30 (permalink) Old 06-25-2009, 07:26 PM
sickrr's Avatar
i think if you dont run 93 your crazy. i put turbo blue in my older f3 and that makes a world of difference.
sickrr is offline
post #30 of 30 (permalink) Old 06-25-2009, 08:43 PM
You can put 100 octane or higher if you want but if its not tuned you're hurting the motor!
