Will driving slip-on and no PCIII?? - 600RR.net
post #1 of 21 (permalink) Old 05-27-2009, 02:43 PM Thread Starter
Creepin_D's Avatar
I'm sure this has been asked before, but I can't find it. Anyways, just installed the slip-on, but feel I don't have the skills/talent to install the PCIII. The Honda dealer ship is about 400k away. Should I be fine to drive my bike that far to get them to install the PCIII??
Thanks
Creepin_D is offline
post #2 of 21 (permalink) Old 05-27-2009, 03:37 PM
600Driver's Avatar
Your CBR should run just fine with a slip-on exhaust. You don't need a PCIII at all since the s/o doesn't change the air/fuel ratio much, if at all, from stock. If you're planning on adding a full system (header) later or an aftermarket air filter, then you'll need it.
I just installed an Arrow Indy-Race slipon a few days ago. My RR is 100% stock otherwise and it runs perfectly, with no issues.
2007 CBR600RR
* Arrow Indy-Race Ti/Cf exhaust.
Michelin Pilot Power 2CT Tires.
* Shorai Lithium Battery
* Cox Racing radiator guard.
* Amsoil 10w-40 synthetic (MCF).
* Engine Ice coolant.
* Rizoma Zero-11 LED turn signals.
* Proton LED flush mount signals.
* Signal Dynamics BackOff XP.
* 3M paint protection film pkg.
600Driver is offline
post #3 of 21 (permalink) Old 05-27-2009, 03:41 PM
jetpuff77's Avatar
if you installed the slipon yourself, and you are able to do an oil change on your bike.. you should be able to install a pc3.. plus im sure there is a writeup on here somewhere.
jetpuff77 is offline
post #4 of 21 (permalink) Old 05-27-2009, 03:48 PM
NewRedRider's Avatar
Images: 24
Thanks
Yes it's been discussed before. There is NO guaranty on how a different pipe will effect your bikes fuel map. My Leo Vince did require a PCIII.
Not an accurate statement. You can't predict how his pipe will effect his bikes fuel map. No one can. If you change ANY part that could effect the fuel map you could run into problems. Heavy loping on cold starts, bad fuel mileage, and hesitation/lag at certain rpm levels are just a few potential problems. Left unchecked this can lead to carbon build-up and plug fouling.
You can take a chance and see how it goes. But if you start seeing any of the symptoms described above get the fuel map checked. :hump:
NewRedRider is offline
post #5 of 21 (permalink) Old 05-27-2009, 04:13 PM
Images: 24
Thanks
Driving to the dealership should be fine as long as you're not running lean. Keep an eye on your temps for any increase. Are they going to be dyno tuning the bike also? If not, save your money. It's easier than you think. Especially if you've already installed the SO by yourself.
post #6 of 21 (permalink) Old 05-27-2009, 04:15 PM Thread Starter
Creepin_D's Avatar
Thanks guyz, I do plan on installing the PCIII, I just need to drive about 4hrs to get to my dealer. SOrry about the double post, was not intentional!!
post #7 of 21 (permalink) Old 05-27-2009, 04:22 PM
Images: 24
^NP bro. GL!
post #8 of 21 (permalink) Old 05-28-2009, 08:24 AM
The worst part about the pc3 install is getting the injector plugs off. It really helps if you have good hands. Also while you are in there pull open your airbox and slip a 5/8 rubber cap over your pair inlet. That will make tuning much easier.
gf8coupe is offline
post #9 of 21 (permalink) Old 05-29-2009, 06:31 AM
Bevo's Avatar
Here's an email from Akrapovič regarding their slip-on:
Dear sir,
Our systems are designed to work properly on stock engine managment, so no changes are needed, this is your option or wish. All power measurements that we make are based on complete stock bikes.
Thank you for your question,
Best regards,
Akrapovič d.d.
R&D department
Bevo is offline
post #10 of 21 (permalink) Old 05-29-2009, 09:52 AM
Images: 24
I will say again....
No one....can predict....how a pipe....will effect....your bikes fuel map. Not even the pipe manufacturer or Honda can predict with 100% certainty all of the variables. That's why some motors get better HP and some get better MPG.
post #11 of 21 (permalink) Old 05-29-2009, 10:40 AM
Bevo's Avatar
Does each and every CBR600RR leave the factory with a custom map?
Bevo is offline
post #12 of 21 (permalink) Old 05-29-2009, 10:57 AM
Images: 24
Nope....That's why they are all different. That's why we buy PCIII's to optimize the fuel map to our bikes individual variables. They might be relatively close. But they are all a little different. That's why when you change something that effects the fuel map (i.e. exhaust pipe, air filter, velocity stacks), it can have a different outcome on each bike.
post #13 of 21 (permalink) Old 05-29-2009, 11:10 AM
Bevo's Avatar
I'd be willing to bet that variables in air temperature, pressure and humidity have a greater affect on bike performance than variables between each individual Akra slip-on
Bevo is offline
post #14 of 21 (permalink) Old 05-29-2009, 12:07 PM
Images: 24
I totally agree.
But the variables that I'm talking about are not in the aftermarket pipe but rather in the valve clearances, camshafts, fuel injectors, velocity stacks, etc...Variables in the bike production.
post #15 of 21 (permalink) Old 05-29-2009, 12:21 PM
Bevo's Avatar
I totally agree.
If you're talking about pure Honda factory and street riding then I think that's splitting hairs
Bevo is offline
post #16 of 21 (permalink) Old 05-29-2009, 12:43 PM
Images: 24
Dyno sheets from various bikes will prove otherwise.
post #17 of 21 (permalink) Old 05-29-2009, 12:47 PM
Bevo's Avatar
All on the exact same Dyno under the exact same conditions with factory fresh bikes? I'd like to see those sheets
Bevo is offline
post #18 of 21 (permalink) Old 05-29-2009, 12:50 PM
Images: 24
Go to a free dyno run promo and watch the stock bikes. I'm sure their will be a local shop doing a promo sometime this summer.
You can run 6 stock bikes and come back with 6 different fuel maps and performance curves. Those small variables do make a difference.
post #19 of 21 (permalink) Old 05-29-2009, 12:55 PM
Bevo's Avatar
Give me a performance differential by percentage. What's the error rate of the Dyno?
Bevo is offline
post #20 of 21 (permalink) Old 05-29-2009, 01:08 PM
Images: 24
It's much easier just to hold two dyno sheets up to the light and compare them.
Error rate for the dyno? Are you trying to say that the dyno is causing the difference from 2 "identical" bikes?
post #21 of 21 (permalink) Old 05-29-2009, 01:16 PM
Bevo's Avatar
What I'm saying is that even if you Dyno'd the same bike twice, there will be a slight difference in results. Dynos are not perfect either and have an error rate
Bevo is offline
