full LeoVince install problem?? - 600RR.net
post #1 of 10 (permalink) Old 07-30-2009, 05:05 PM Thread Starter
BLUETORI's Avatar
Okay i have searched and am stuck. I am installing a full LeoVince exhaust on my 07 and am having issues with how to hook up the servo/butterfly valve to the midpipe. Does anyone know how this works and pics to do it? This is the only thing holding me back.
PM me if you have a red clip for an Arai side pod.
BLUETORI is offline
post #2 of 10 (permalink) Old 07-30-2009, 05:35 PM
you dont you throw that hunk of metal in teh garbage
k4lcartman is offline
post #3 of 10 (permalink) Old 07-30-2009, 06:02 PM Thread Starter
BLUETORI's Avatar
Are you being serious the round piece that has the 2 cables going to the flapper valve. I was told that was what it is called.
BLUETORI is offline
post #4 of 10 (permalink) Old 07-30-2009, 06:49 PM
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
Just checked all the install instructions for full systems from there site and none of them include the use of the servo/cables/valve.
I have a KR tuned and I just left the motor in place and took the cables off it.
https://www.leovinceusa.com/schemati...-7759-7760.pdf
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #5 of 10 (permalink) Old 07-30-2009, 06:57 PM Thread Starter
BLUETORI's Avatar
^So that's probably why you need the Power Commander. I just didn't know if it would throw up the FI light. I guess I'm good then and I can start to hookup my PCIII. Unless there is something else guys?
BLUETORI is offline
post #6 of 10 (permalink) Old 07-30-2009, 07:25 PM
cnk
cnk's Avatar
You can disconnect the cables from the servo under the seat, but don't disconnect the module as it will throw a light.
2007 Pearl White
OEM seat cowl
HRC CF trim set
R&G aero sliders, cotton reels, bar ends, swingarm protectors
Pazzo shorties
Cox radiator guard
White reflective rim tape
Tripage IT
Tripage adjustable FE
Akrapovic S/O
Dynojet PC3 USB
PAIR plates
Watsen flushmounts
Techspec pads
5000K DDM HID's
Woodcraft clutch/stator covers, rearsets, and shark fin
Ohlins 25mm fork cartridges
Ohlins TTX rear shock
HEL SS brake lines
Brembo RCS19 MC
Gilles TECA chain adjusters and crash pads
cnk is offline
post #7 of 10 (permalink) Old 07-30-2009, 07:28 PM Thread Starter
BLUETORI's Avatar
Okay well I just started it up and it sounds like it is popping and it almost looks like the header isn't flush with the block should it? Or does it set off a little bit? I also haven't installed the PCIII and was wondering if that is the reason it sounds that way.
BLUETORI is offline
post #8 of 10 (permalink) Old 08-04-2009, 06:15 PM
Dr. GoFast's Avatar
call leo vince : 510-232-4040
2004 Honda CBR600RR
-Spiegler SS lines f+r
-Woodcraft rearsets
-Woodcraft Clip-Ons
-GPR Steering Damper
-Vesrah RJL brake pads
-Elka 3-Way Shock
-CRG gold levers
-Leo Vince Full Exhaust
-PCIII
-green painted rims
-puig d-bubble screen
-Pro-impact Frame sliders
-EK MVXZ 520 green chain w/ Pit bull sprockets (-1/+1)
- .9 kg/mm constant-rate fork springs +re-valving
-Tanktredz
Dr. GoFast is offline
post #9 of 10 (permalink) Old 08-04-2009, 06:29 PM Thread Starter
BLUETORI's Avatar
Pretty much installed waiting on a set of new studs for the block since I broke one. Figured I'd replace them all while it's apart. Then I can map it.
BLUETORI is offline
post #10 of 10 (permalink) Old 08-04-2009, 07:10 PM
Dr. GoFast's Avatar
^^ make sure you remove your copper exhaust manifold gaskets if need-be, otherwise they'll leak everytime. also, when installing the new studs, you don't need to torque them down at all, pretty much just hand tight. check your service manual for the torque for the nuts- it's isn't much.
when installing and removing studs, nuts, etc... always make sure the engine is stone cold.
2004 Honda CBR600RR
-Woodcraft rearsets
-Woodcraft Clip-Ons
-Elka 3-Way Shock
-CRG gold levers
-PCIII
-green painted rims
-Tanktredz
