Opinions on race fuel - 600RR.net
post #1 of 37 (permalink) Old 08-17-2009, 08:53 PM Thread Starter
I was wondering on the engines ability to handle 111 octane race gas....ive ran te bike on it one time at the drags and it really came alive....but was told that the higher the octane the higher the lead content in the fuel and was also told that no fuel was truly 'unleaded' .The lead in the fuel is hard on the injectors from my understanding but is it ok to run this occasionally ie at the drags? Thanx
909 Racing is offline
post #2 of 37 (permalink) Old 08-18-2009, 07:28 AM
The lead will destroy the cat, if you still have that in your exhaust. It can also hurt some O2 sensors.
If you don't make any other changes to your bike, like raising the compression and/ or adjusting ignition timing, you will not see any benefits from race gas. With some types of race gas, power may go down because specific energy is less. The higher octane rating only signifies resistance to detonation. There are some types of race gas with higher energy density (oxygenated etc).
OP
opodden is offline
post #3 of 37 (permalink) Old 08-18-2009, 09:50 AM
CTM_Patron's Avatar
yea, unless you've modded the engine don't waste your money on race fuel. besides that good smell, ur not going to be benefiting from it.
CTM_Patron is offline
post #4 of 37 (permalink) Old 08-18-2009, 10:17 AM
E-NA6CE's Avatar
Images: 2
Pft! I run race fuel in my Roadster and that thing hauls ass. I only got high 400's for RWHP running 110 Unleaded and nailed 603.0 RWHP using leaded race fuel. Although, it's ridiculously over-priced.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #5 of 37 (permalink) Old 08-18-2009, 10:19 AM
CTM_Patron's Avatar
ur also french
post #6 of 37 (permalink) Old 08-18-2009, 10:24 AM
E-NA6CE's Avatar
Images: 2
ur also french
Negative, my pendejo friend. I am of teh yellow-skinned breed. I am Asian.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #7 of 37 (permalink) Old 08-18-2009, 10:27 AM
CTM_Patron's Avatar
u really think race fuel FTW though???? i've always heard that you should select the fuel with the lowest possible octane that will prevent detonation in your engine.
post #8 of 37 (permalink) Old 08-18-2009, 10:36 AM
1ofakindRR's Avatar
It's all about oxygenated... And my '06 has ALL the emissions crap pulled since we don't do emissions in Colorado.
Solar White RR6 "Pearl"
R.I.P. PHATTY!
Caution: Beware of whores.........
1ofakindRR is offline
post #9 of 37 (permalink) Old 08-18-2009, 10:41 AM
E-NA6CE's Avatar
Images: 2
I'd rather use race fuel if I could get around the whole fuel system changes. It smells awesome, burns your eyes, yields a more relentless combustion, combustion is cooler and it's much, much better for obtaining continuous, predictable performance.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #10 of 37 (permalink) Old 08-18-2009, 10:44 AM
CTM_Patron's Avatar
yea based on smell alone, race fuel ftw!!!! jhahahaha
post #11 of 37 (permalink) Old 08-18-2009, 11:41 AM Thread Starter
i differ on the fact that race gas doesnt build power....as stated i ran 111 at an eighth mile track....started nite off on premium and went almost completely empty so i bought 2 gallons of 111 and two passes later dropped two tenths of a second....same rpm launch 60 foot times were almost identical.....
post #12 of 37 (permalink) Old 08-18-2009, 11:50 AM
E-NA6CE's Avatar
Images: 2
You do realize you had less weight in your fuel cell, right? That will contribute to a lower time.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #13 of 37 (permalink) Old 08-18-2009, 12:47 PM
CTM_Patron's Avatar
i run race fuel in my miata FTMFW!!!!!!!!!!
post #14 of 37 (permalink) Old 08-18-2009, 12:48 PM
E-NA6CE's Avatar
Images: 2
Oh, you mean the car in your avatar, which is mine? You fucker. Stop fronting that it's yours.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #15 of 37 (permalink) Old 08-18-2009, 12:56 PM
*BOTM Feb '11, Mar '12*
sincalirider's Avatar
Feedback Score: 27 reviews
I thought the lead was good for the block as well? Doesn't it put a coat on the cylinder walls to give a lil protection IIRC?
sincalirider is offline
post #16 of 37 (permalink) Old 08-18-2009, 12:57 PM
CTM_Patron's Avatar
i eat lead for breakfast
post #17 of 37 (permalink) Old 08-18-2009, 12:59 PM
E-NA6CE's Avatar
Images: 2
Anything that coats the cylinder walls will boost compression. Wouldn't that be a bad thing? Secondly, wouldn't your rings prevent this from happening unless they were fucked up?
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #18 of 37 (permalink) Old 08-18-2009, 01:08 PM
HighNoonHonda's Avatar
+1.... I agree with this insight.... I would suggest that you run what is suggested in your manual.. Unless you modify your ignition and exhaust the performance boost will only be a fraction of what it could be if you properly tune you engine per the fuel you are using... It's all about the Ratio's (fuel/air and number of carbon to oxygen bonds the make up the fuel).
you can put just about anything that burns in the tank... for instance i had to use acetone in another bike just to get to a gas station, not that this was a good idea but it worked. sure i took notice of a mild performance increase but at what cost??
HighNoonHonda is offline
post #19 of 37 (permalink) Old 08-18-2009, 01:47 PM
I have to reread where I got that from, it was a while ago. But I remember hearing that too, that the lead was good for the motor. Something about filling any pits or imperfections in the cylinder wall. Microscopic ones of course but still some what beneficial non the less.
post #20 of 37 (permalink) Old 08-18-2009, 01:48 PM
E-NA6CE's Avatar
Images: 2
Ah, well that would make sense for sure. Albeit lead being a soft metal, it should just burn up or be expelled during the exhaust stroke. But it does make sense. I was thinking of an actual coating, bah ha ha ha. FML
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #21 of 37 (permalink) Old 08-18-2009, 02:35 PM
Mad Chemist
WherzRoony's Avatar
Images: 57
+1000000000
I love that smell, I run a blend of it it in my chain saw, weed eater and a few other yard tools just for that intoxicating smell
It does give the chainsaw a bit more kick. I started using it because a lot of the pro loggers around here use it.
I Like My Guns Like Obama Likes His Voters: Undocumented
WherzRoony is offline
post #22 of 37 (permalink) Old 08-18-2009, 03:56 PM
HighlyFavored0420's Avatar
So why does Jesse James run it in EVERY project he makes, regardless if it's the stock engine or not?
'08 motofans custom - crg, akra, puig db, watsens, audi, IT tail light, tripage fe & gas cap, r&g, ddm
DIY HID on/off switch with LED running lights: https://www.600rr.net/vb/showthread.php?t=150450
HighlyFavored0420 is offline
post #23 of 37 (permalink) Old 08-18-2009, 04:06 PM
E-NA6CE's Avatar
Images: 2
Yeah well, you need to understand that he's a redneck. About as redneck as they come. If I could run leaded race fuel in all of my vehicles then I would. You also have to take into account that he has a fuel sponsor, which is probably why he does it.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #24 of 37 (permalink) Old 08-18-2009, 04:09 PM
And I also put the in there to imply that I was being sarcastic.
post #25 of 37 (permalink) Old 08-18-2009, 04:22 PM
E-NA6CE's Avatar
Images: 2
Oh, ha ha ha ha ha ha. Fu*k me sideways. I thought you were doing that for other reasons (ie: the posters above were retarded or something).
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #26 of 37 (permalink) Old 08-18-2009, 04:23 PM
CTM_Patron's Avatar
like when i quote nero and put
post #27 of 37 (permalink) Old 08-18-2009, 04:33 PM
E-NA6CE's Avatar
Images: 2
That's because you don't have the intellectual capacity to understand my technical responses. Don't hate.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #28 of 37 (permalink) Old 08-18-2009, 04:36 PM
CTM_Patron's Avatar
in order to hate, i would have to be capable of feeling emotions, which i am not:all_cohol
post #29 of 37 (permalink) Old 08-18-2009, 04:38 PM
E-NA6CE's Avatar
Images: 2
You know where we sit on that. Damn right. Emotions are the enemy.
R.I.P. Chenhan
2008 600RR
2010 ZX-6R
E-NA6CE is offline
post #30 of 37 (permalink) Old 08-18-2009, 04:41 PM
CTM_Patron's Avatar
and my post count is bigger than yours, so HA! :all_cohol
