Gas tank pressure pushing/sucking on fuel cap?? - 600RR.net
post #1 of 12 (permalink) Old 09-23-2009, 06:49 PM Thread Starter
MachRider's Avatar
Images: 8
Recently installed a PCV so I had the bike more or less taken apart with my father.
Long story short, when I open up my fuel cap now (it's stock) the cap will either stick to it's track and have to suck back up (like a vacuum is holding it down) or it will blow off when I twist the key. I'm really perplexed and worried about this because I really can't think of what we did wrong.
Where would this problem be rooted? I'd imagine some sort of line is pinched from us assembling the bike back together, but does anyone know what this is exactly? I'm afraid to ride it after just filling it up and the damn cap blew off like a rocket, almost breaking my f%*#ing finger.
EDIT: I noticed my large rubber hose, which I assume is some sort of breather hose, doesn't hang as low as it did before dis assembly. Probably it?
93
MachRider is offline
post #2 of 12 (permalink) Old 09-23-2009, 07:33 PM
tripage's Avatar
Feedback Score: 91 reviews
Check your vacuum hoses and make sure they are not plugged or pinched.. T
http://tripageled.com/store/
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
post #3 of 12 (permalink) Old 09-23-2009, 07:48 PM Thread Starter
MachRider's Avatar
Images: 8
Part #57 is what I was referring to about a hose, labeled as a BREATHER HOSE. It ends up down by the kick stand... what do you think? Weird thing is it just seems like an overfill hose to me since it goes to the tray around the basket and out the bottom of the tank via a slip-on male end to the tube- something that shouldn't take pressure well.
What would you say is the likely problematic hose, trip? Thanks for your help.
93
post #4 of 12 (permalink) Old 09-23-2009, 08:15 PM
tripage's Avatar
57 goes to your fuel pump... I would pull your tank and check the hoses to make sure they are not pinched, this is probably the problem one got stuck when you lowered the tank down and now it can't vent and is building pressure in the tank.. T
Owner
Tristan Page
[email protected]
[email protected]
tripage is offline
The Following User Says Thank You to tripage For This Useful Post:
MikeyP (03-06-2013)
post #5 of 12 (permalink) Old 09-23-2009, 09:22 PM
dcope17's Avatar
Sounds like a pinched breather hose to me too.
dcope17 is offline
post #6 of 12 (permalink) Old 09-23-2009, 10:03 PM
i agree with everyone in the pinched breather hose. when it gets hot, pressure builds and needs to go somewhere as gas evaps.
2008 Liquid Silver CBR600RR
Purchased 10/25/2008, Totaled 10/28/2008 by the dealer
New 2008 Liquid Silver CBR600RR....delivered 10/30/2008
bms231 is offline
post #7 of 12 (permalink) Old 03-06-2013, 04:47 PM
rlee350's Avatar
so what was the answer to this? i have the exact same problem i've checked the hoses and everything seems to be in order.
rlee350 is offline
post #8 of 12 (permalink) Old 03-06-2013, 07:03 PM
Definitely the breather hose - I did the same thing when I installed my PCV. It helps to pull the hoses up then drop the tank, then pull the hoses back down to their normal position
DiscoRR is offline
post #9 of 12 (permalink) Old 03-06-2013, 07:50 PM
MikeyP's Avatar
Feedback Score: 10 reviews
Pinched/clogged hoses for the win!!!
2008 CBR 600RR #1 (Graffiti) street
2008 CBR 600RR #2 track
CMRA #599
Originally Posted by MikeyP View Post
Unfortunately bikes fall over. It's in their nature.
It's our job to keep them upright, but we are only men.
MikeyP is offline
post #10 of 12 (permalink) Old 03-07-2013, 01:54 AM
BOTM Winner 1/13
Nuttynu's Avatar
Did u use diesel ?
My Ride Report :
-Alaska,The Last Frontier
Nuttynu is offline
post #11 of 12 (permalink) Old 03-07-2013, 07:20 PM
my04600's Avatar
I work on new heavy construction equipment full time+ and had a guy put about 40 gallons of diesel in the hydraulic tank. The machines come to usa from all over the world. Dresta comes from polland and their dozers have the FUEL tank on one rear side and the HYD tank on the other rear side. He drove it off the trailer and because it was low on fuel he took it to the fuel truk like he was supposed to do but pumped the fuel in the wrong tank. Wasn't a good ending for Vladamir.
DON"T EVEN STINK
my04600 is offline
post #12 of 12 (permalink) Old 03-07-2013, 09:36 PM
rlee350's Avatar
No diesel. The hose was too short to poke out by the kickstand on the armour bodies. I stretched it and zip tied it to the other hose seems to work for now. I messages some other people and one person said it was the gas tank seal from the top.
Sent from Motorcycle.com App
rlee350 is offline
