PAIR valve removal, purpose? - 600RR.net
post #1 of 22 (permalink) Old 10-20-2009, 09:37 PM Thread Starter
BOTM Winner 07/12
03WisconsinRR's Avatar
Images: 8
Feedback Score: 17 reviews
So whats the reason for the removal of the PAIR valve? Is it just for weight? I've read there is a performance increase but others say there isnt.
If theres a reason to do this I'll take care of it this winter, if not I'm going to leave it.
Thanks
08'RR
Akra Evo TI - Bazzaz ZfiTc - Acumen Gear Indicator - Yoyo Stay - Keyless Mod - Michelin Power Cup - HRC overflow - ECUnleashed
Yoyo Slipper - Galfer Lines - HRC Rear Res - HRC Throttle - Woodcraft Sliders - Woodcraft Rearsets - Servo Mod - Samco Hoses
BMC - Hotbodies - Brembo RCS19 - Penske 8987 & 20mm Valving - ASV Levers - Rk 520 - GPR Damper - EBC XC Rotors
Woodcraft Clipons - Gilles Chain Adjuster - R&R Subframe - PAIR Mod - Cox Rad Guard - MOYT 4 cell - Factory Pro Shift Star
03WisconsinRR is offline
post #2 of 22 (permalink) Old 10-20-2009, 09:40 PM
tenjin's Avatar
the search button tells me weight, and a proper tuning after exhaust and airfilter mods.
DDM 55w 7k HID
Sliders
Black Vortex Rearsets
R&G Bar Ends
Black passenger pegs
JPR Shorty levers
EK 520MVXZ black chain
Versah RJL Brake pads
Flushmounts
fender eliminator
Pair Delete
Bazzaz AFM
tenjin is offline
post #3 of 22 (permalink) Old 10-20-2009, 09:45 PM
murphdog1411's Avatar
Images: 94
There is a small weight savings, although the main idea is so that you can get a proper dynotune. The PAIR system injects air into the exhaust for emissions. With the system installed, the tuner would be getting sparatic readings since his sensor is reading the burnt air/fuel mix from the cylinders as well as fresh air from the pair system. This would give a false reading and a proper tune could not be done.
murphdog1411 is offline
post #4 of 22 (permalink) Old 10-20-2009, 09:50 PM Thread Starter
BOTM Winner 07/12
Images: 8
We'll thats way to much work for that little gain. I just pinched off the hose when I had my dyno done so I think I'll save myself the hassle and pass.
08'RR
post #5 of 22 (permalink) Old 10-21-2009, 01:22 AM
stormy's Avatar
Feedback Score: 11 reviews
here you go go a go go
The exhaust emission control system consists of a secondary air supply system which introduces filtered air into the exhaust gases in the exhaust port. Fresh air is drawn into the exhaust port whenever there is a negative pressure pulse in the exhaust system. This charge of fresh air promotes burning of the unburned exhaust gases and changes a considerable amount of hydrocarbons and carbon monoxide into relatively harmless carbon dioxide and water vapor. The PAIR system is controlled by the ECM using check valves and a solenoid.
Removal of the PAIR system will yield three main benefits: 1) weight reduction 2) reduction of engine compartment clutter 3) increase in the scavenging ability of the exhaust system.
stormy is offline
post #6 of 22 (permalink) Old 10-21-2009, 02:19 AM
SHORTSTACK's Avatar
Feedback Score: 15 reviews
its not a pian in the a55. its really easy.
R.I.P. PHATTY
SHORTSTACK is offline
post #7 of 22 (permalink) Old 10-26-2009, 01:00 PM
Yup, he's right.
Most dyno tuners will just block that hose or pinch it. You don't gain any performance by removal either, nor do you really gain weight savings. I mean cmon, were not riding our bikes everyday to compete anyways.....so that "less than 5 pounds" saving means "dyck".
People just do it for convience when they tune their bikes, but that's done by those who compete and do it often.
There is a guy on 1000rr.net site that actually made pair block off plates, I don't know if he still does it though.
Bucs Anthem is offline
post #8 of 22 (permalink) Old 10-26-2009, 01:06 PM
SLAPS808's Avatar
Feedback Score: 56 reviews
Originally Posted by Bucs Anthem View Post
Yup, he's right.
i thought it was for the looks?
SLAPS808 is offline
post #9 of 22 (permalink) Old 10-26-2009, 01:34 PM
i'm guessing the bike wont pass the emission test after that correct?
bboynicku is offline
post #10 of 22 (permalink) Old 10-26-2009, 01:36 PM
SLAPS808's Avatar
if there was an emission test...then no it wont.
SLAPS808 is offline
post #11 of 22 (permalink) Old 10-29-2009, 08:49 AM
LOL!!!!! Yeah, my bike looks super sexy under the tank.....and it gave a whooping 10hp increase!!!! WOOT!!!! WOOT!!!!!
post #12 of 22 (permalink) Old 10-29-2009, 03:16 PM
SLAPS808's Avatar
mine too, but i didnt gain any hp.
SLAPS808 is offline
post #13 of 22 (permalink) Old 10-29-2009, 04:19 PM
The Asian Persuasion
Phatstud's Avatar
Feedback Score: 65 reviews
I hope my will look pretty after I figure out how to install it haha
Phatstud is offline
post #14 of 22 (permalink) Old 10-29-2009, 04:20 PM
Phatstud's Avatar
There's a vendor here that does also.
Phatstud is offline
post #15 of 22 (permalink) Old 10-29-2009, 04:52 PM
ccs907's Avatar
questions.
1. how in the almighty HELL does the tuner "pinch it shut" when the hoses are wedged under the airbox? seriously, you cannot get the the lines without removing the box.
2. The system only activates under negative load (throttle down). this would not effect throttle up operation, which is what dyno tuners tune to, sooooo........
3: Capping the system will make the bike produce more emissions, however it may not be detected by the 4 gas analyzer.
ccs907
ccs907 is offline
The Following User Says Thank You to ccs907 For This Useful Post:
SaratogaLED (04-26-2018)
post #16 of 22 (permalink) Old 10-29-2009, 06:10 PM Thread Starter
BOTM Winner 07/12
Images: 8
Both inlet hoses can be accessed from the sides of the bike with the fairings off, or you can plug the main inlet inside the airbox.
08'RR
post #17 of 22 (permalink) Old 10-29-2009, 06:16 PM
ccs907's Avatar
if you say so. i certainly don't recall seeing them the countless times i've had my fairings off, but then again, i was looking either. i can't imagine a tuner doing anything more than strapping the bike down and sticking a AF line down the pipe... let alone removing any bodywork or diving inside the airbox...
ccs907
ccs907 is offline
post #18 of 22 (permalink) Old 10-29-2009, 06:37 PM Thread Starter
BOTM Winner 07/12
Images: 8
Your profile says you have an 06'. I've only seen my 08' in that respect. They may be different.
As for the tuner doing it. No, I dont think they would either which is why I did it myself.
Left inlet hose
Right inlet hose
08'RR
post #19 of 22 (permalink) Old 10-29-2009, 06:46 PM
I noticed a reduced amount of popping and cracking on decel after removing the pair system. I also had a slip on with no cats.
blue 07 600rr
A22 nesba
urotech is offline
The Following User Says Thank You to urotech For This Useful Post:
post #20 of 22 (permalink) Old 10-29-2009, 07:14 PM
ccs907's Avatar
that's to be expected. the PAIR burns off excessive hydrocarbons left after combustion while still inside the exhaust pipe by adding O2 allowing combustion to take place, which produces mini explosions in the pipe.
ccs907
ccs907 is offline
post #21 of 22 (permalink) Old 10-29-2009, 11:09 PM
SLAPS808's Avatar
07-09 rr's are easier to access the pair valve and hoses.
its really not much more difficult on the 03-06 rr's.
just loosen the bolts on the radiator and push it back...
you can access the pair to block off the tubes or pinch them.
if youre gonna do the complete makeover...then removing
the airbox is a must on all the rr's.
i wish i took pics of me performing this on my old '05 rr.
damn shame i dont take pics of everything i do.
SLAPS808 is offline
post #22 of 22 (permalink) Old 10-30-2009, 01:48 PM
Here's a "tuner" insider secret:
If you stick a double RR sticker below your air box......it gives you an extra 5 hp and you'll be able to do 200 mph!!!!!!
ZZZZZZZRRRRRROOOOOOOMMMMMMM!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!
