gas tank removal - 600RR.net
post #1 of 13 (permalink) Old 04-12-2013, 02:45 PM Thread Starter
runout234's Avatar
gas tank removal
I am installing a power commander on my 09 cbr600rr and i was wondering, when removing the gas tank, do i have to worry about fuel being in the tank when removing or is there a valve that cuts off the gas supply?
runout234 is offline
post #2 of 13 (permalink) Old 04-12-2013, 05:28 PM
dsid's Avatar
I wouldn't worry about it. I have taken fuel tank of without removing fuel. When u take fuel hose off just use a cloth ...
2007 CBR600RR Konica Minolta (blue/white)
dsid is offline
The Following User Says Thank You to dsid For This Useful Post:
runout234 (04-12-2013)
post #3 of 13 (permalink) Old 04-12-2013, 05:43 PM Thread Starter
runout234's Avatar
Ya but the problem with using a cloth with a large amount of fuel is that it has a greater chance of leaking everywhere, especially with a cloth. Im thinking that it might be best to drain it first then use the cloth to refrain from small leakages.
post #4 of 13 (permalink) Old 04-12-2013, 06:09 PM
dsid's Avatar
I won't leak out. The cloth is just for the little bit of fuel in the fuel hose.
dsid is offline
post #5 of 13 (permalink) Old 04-12-2013, 06:37 PM Thread Starter
runout234's Avatar
Ah, alright. I get you now. thanks for your help.
post #6 of 13 (permalink) Old 04-12-2013, 09:48 PM
you can just pivot the tank on the back mounting, and get enough clearance to do the job.
tary preisser is offline
The Following User Says Thank You to tary preisser For This Useful Post:
post #7 of 13 (permalink) Old 04-12-2013, 10:30 PM Thread Starter
runout234's Avatar
Do i still have to disconnect the hoses and wiring from the tank?
post #8 of 13 (permalink) Old 04-13-2013, 02:16 AM
dsid's Avatar
Depends on how much clearance you need. If you only need a little bit you do not have to disconnect but if you disconnect you will get a lot of clearance
dsid is offline
post #9 of 13 (permalink) Old 04-13-2013, 02:24 AM
dsid's Avatar
Fuel hose will be the only thing constricting the amount you can lift your tank as its connected elsewhere. The other breather hose and overflow hose are free at the end. They don't connect to anything. Sonifnu remove the fuel hose from the tank. You are free to go. Just make sure u don't pinch the vent hose when u set the tank back down.
dsid is offline
runout234 (04-13-2013)
post #10 of 13 (permalink) Old 04-13-2013, 02:24 AM
dsid's Avatar
Sonifnu***= so if u ..... Lolll
dsid is offline
post #11 of 13 (permalink) Old 04-13-2013, 11:55 AM Thread Starter
runout234's Avatar
Alright thanks for your help. As you can tell, I have yet to attempt to remove my gas tank. The last bike i had was an enduro, which was carbureted so it had a valve to switch off the fuel. This information will come into some good use.
btw, win, lol
post #12 of 13 (permalink) Old 12-26-2016, 01:04 PM
How did you remove the tank on your CBR ? Do you have an instruction guide, DIY write up with pictures or a video link you can provide ??
DatBoyAli is offline
post #13 of 13 (permalink) Old 12-26-2016, 08:46 PM
if installing power comander or such, no need to remove tank.
just rotate/flip it up, using the by the seat mounting point as a pivot.
Highly recommend you use search OTF for "pinched gas tank lines" and "collapsed tank".......
