Injector unit leaking - 600RR.net
post #1 of 8 (permalink) Old 07-05-2013, 06:00 AM Thread Starter
mike992's Avatar
Hi,
Had to remove the airbox, in which we also un-mounted the fuel injectors. Bolted everything back up however when turning the bike on there is considerable fuel leaking which seems to come from the fuel injector housing or the injecters them selves. Is there anything that we may have put back wrong? Seems so simple but fuel is squirting out through the injector housing, as if the airbox was blocked and the fuel had nowhere else to go.
Appreciate any help - Regards, Mike
mike992 is offline
post #2 of 8 (permalink) Old 07-05-2013, 07:04 AM
Lose hose or fuel connection somewhere?
Still leaking or a spill from when you moved tank?
Zer0HedgeTrader is offline
post #3 of 8 (permalink) Old 07-05-2013, 08:52 AM Thread Starter
mike992's Avatar
Its like spraying out of the injector housing, as you can see above. (above isnt exact same model)
mike992 is offline
post #4 of 8 (permalink) Old 07-05-2013, 08:57 AM Thread Starter
mike992's Avatar
We did is un-bolt the injector from the housing, they were working OK before.
mike992 is offline
post #5 of 8 (permalink) Old 07-05-2013, 09:28 AM
OveRReV's Avatar
Images: 16
most likely one of the o-rings is ruptured, try to locate the part & replace it.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
The Following User Says Thank You to OveRReV For This Useful Post:
mike992 (07-06-2013)
post #6 of 8 (permalink) Old 07-06-2013, 03:56 PM Thread Starter
mike992's Avatar
you were correct, thanks. One question, how to replace the new o-ring? use a lubricant I presume and push it in injector housing?
mike992 is offline
post #7 of 8 (permalink) Old 07-06-2013, 07:52 PM
OveRReV's Avatar
Images: 16
yeah, just wet the o-rings with oil or grease so it slides in without damaging the rubber.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
post #8 of 8 (permalink) Old 07-07-2013, 04:15 AM Thread Starter
mike992's Avatar
Thank you,
mike992 is offline
