Do i need a power commander? - 600RR.net
post #1 of 18 (permalink) Old 08-13-2013, 01:53 PM Thread Starter
I was at a bar last night and a guy was asking me about my Yoshi pipe, he asked if I had a power commander and being the novice I am, I gave him a blank look. He explained briefly what a power commander is and that I should put one in.
My questions Are: Do I need one mechanically speaking? Is it bad for my bike not to have one with a Yoshi Pipe? What are the benefits of putting one in?
I have an '05 CBR 600RR
EthanG.FCE is offline
post #2 of 18 (permalink) Old 08-13-2013, 01:54 PM
BOTM Winner 8/12 / Super Moderator
CBR Time's Avatar
Images: 45
Feedback Score: 12 reviews
Do you have a SO on full system? short answer SO - No dont need one, Full System - Yes i rec
CBR Time is offline
post #3 of 18 (permalink) Old 08-13-2013, 02:04 PM
Bridge_Jumper's Avatar
Feedback Score: 5 reviews
Do you need one? no
If you install an aftermarket air filter in addition to your slip on do you need one? no
Will a power commander help with those 2 mods? Yes
I have a slip on and a k&n air filter on my bike, no power commander. The bike runs a little lean, but I'm fine with it because right now I don't have the time and money to install a power commander
2006 Honda CBR600RR Black Tribal Edition
2W1R - IceTitan
Bridge_Jumper is offline
post #4 of 18 (permalink) Old 08-13-2013, 02:25 PM
Rad Rage's Avatar
Let me simplify this for you:
State of bike scenarios:
- Completely stock - absolutely no need for PC
- Slip on only - no need for PC
- Aftermarket air filter only - no need for PC
- Slip on and aftermarket air filter - get it if you can afford it.
- Full system (as in slip on, link pipe and headers) Definitely get a PC.
The PC will ensure the air/fuel mixture is optimal for the changes made to the bike. You will need to dyno tune it or purchase the autotune module.
2011 CBR600RR 'X-Ray' Build Thread
https://www.600rr.net/vb/showthread.php?t=294795
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
The Following 7 Users Say Thank You to Rad Rage For This Useful Post:
Ace 1 (05-01-2016), clilholt (01-11-2014), EthanG.FCE (08-13-2013), JRetroCBR (09-23-2013), OveRReV (08-21-2013), raindance (02-12-2014), ThrottleJunkie19 (10-01-2013)
post #5 of 18 (permalink) Old 08-13-2013, 03:12 PM
CBR Time's Avatar
Images: 45
^ pretty much sums it up :)
CBR Time is offline
post #6 of 18 (permalink) Old 09-20-2013, 08:58 AM
Sorry for thread jacking. But whats the difference between PC versions?
J_illest is offline
post #7 of 18 (permalink) Old 09-20-2013, 09:03 AM
the PCIII is discontinued. the PCV is the current model
2W1R - IceTitan
post #8 of 18 (permalink) Old 09-20-2013, 09:54 AM
gotama's Avatar
PC V has more features than the PC III
gotama is offline
post #9 of 18 (permalink) Old 09-23-2013, 12:29 AM
Geno 06RR's Avatar
Exactley this!!!
Live To Ride,Ride To Live
Geno 06RR is offline
post #10 of 18 (permalink) Old 09-30-2013, 11:22 PM
theoddjosh's Avatar
I've got a full Yoshi RS-5 system with a PCIII installed. Although I don't have a custom map, dynojet provides a "Stock CBR600RR + Full RS-5" map template that I'm using. Is this good enough for the mean-time until I can afford a full dyno test?
theoddjosh is offline
post #11 of 18 (permalink) Old 10-01-2013, 02:31 AM
Rad Rage's Avatar
It should be good enough until you get a tune, but the thing is you have to stop for a second and analyze the bike, in other words, do you notice any odd behavior i.e.
- is there too much soot (carbon) on the tip of your exhaust?
- are the temperatures within the safe range or have they suddenly gone up from usual?
These are not conclusive questions but they might help you find out if the bike is running too lean (more air than optimal) or too rich (more fuel than optimal). If the throttle is gradual in its response and you notice no other problems at all, then you should be good for a long time until you get your tune.
Rad Rage is offline
post #12 of 18 (permalink) Old 10-01-2013, 07:31 AM
OveRReV's Avatar
Images: 16
make sure you block your pair valves before you take it to the dyno.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
post #13 of 18 (permalink) Old 10-01-2013, 04:36 PM
ThrottleJunkie19's Avatar
Rad Rage pretty much sums it all up! Gotta SO two bros on mine and about to do air filter and Juice box
ThrottleJunkie19 is offline
post #14 of 18 (permalink) Old 10-05-2013, 04:27 PM
A dyno run will tell you for sure, but to be honest for most it's not needed at all unless you nothing something out of the norm. The Dynojet maps are actually very good. They are not perfect, but are damn good. The thing that people often forget about a dyno tune is that it's only as good as the guy running the dyno. I've seen people pay 350 for a custom tune just to find out the guy loaded the downloaded map into his powercommander, took the 350, and sent him on his way. Never even got a custom tune. Not all dyno operators are created equal is the thing to remember about dyno tunes.
Corey
motomummy is offline
post #15 of 18 (permalink) Old 11-04-2013, 11:32 AM
Power commander
Corey
Hi if you keep the oxygen sensor in the exhaust won't that make sure the mixture is right if you put an after market can and air filter on it. I have a 2007 by the way
Shipleymanx is offline
post #16 of 18 (permalink) Old 11-04-2013, 05:58 PM
JTRC51's Avatar
Corey
WOW.. some people... If my Tuner did that...
JTRC51 is offline
post #17 of 18 (permalink) Old 11-04-2013, 06:25 PM
VangaSTL's Avatar
Another novice question. on the Dynojet website. it says that PC V only works with year models 09 and up. But then on motorcycle superstore, it says that the PC V is compatible with my 05. Whats the deal?
VangaSTL is offline
post #18 of 18 (permalink) Old 11-05-2013, 03:50 AM
OveRReV's Avatar
Images: 16
the PCV will work on 03-06 as well as 07-12 models, they all share the same part numbers so they should work.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
BMC race air filter
Brembo 19RCS MC
HEL brakelines
BST CF wheels
OveRReV is offline
