Best A/F Ratio for Power 07/08 Model - 600RR.net
post #1 of 6 (permalink) Old 09-17-2013, 12:02 PM Thread Starter
mike992's Avatar
Hi guys,
Wondering if anyone who has had their bike taken on a dyno could tell me what the best air/furl ratio at certain RPM is best for power on the 07/08 model?
Perhaps someone whos had their bike tuned could upload an image of their PC AF map so we can see what a/f' numbers the tuner found best at what RPM's.
Thanks
mike992 is offline
post #2 of 6 (permalink) Old 09-17-2013, 12:19 PM
Ldn
Ldn's Avatar
A naturally aspirated gasoline engine will produce maximum power with a slightly rich mix.
14.7:1 is Stoichiometric.
To be rich you want to be around 13:1.
Keep in mind too that all fuel will burn differently and may effect your power production.
Sent from Motorcycle.com App
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
post #3 of 6 (permalink) Old 09-17-2013, 12:24 PM
Ldn
Ldn's Avatar
Also, barometric pressure (elevation) temperature, and humidity will all have an effect of air density causing for a more dense mixture (more air). Or less dense.
Ldn is offline
post #4 of 6 (permalink) Old 09-17-2013, 10:45 PM
go to the "official dyno thread" OTF?
IIRC you want a/f ratio closer to 13 when full throttle, and you can be slightly leaner (13.?) at partial throttle.
use the search, there is a ton of info OTF about this.
tary preisser is offline
post #5 of 6 (permalink) Old 09-17-2013, 11:35 PM
Ldn
Ldn's Avatar
What I was getting to is that for maximum power you want to be rich. BUT, this is very dependent on your setup and location. There is no "best ratio" for everyone, because every ones variables are different. Get a tune done properly for your setup.
Ldn is offline
post #6 of 6 (permalink) Old 09-17-2013, 11:52 PM
OveRReV's Avatar
Images: 16
i am tuning my own PC3 for max power & i found that 13.0:1 AFR is best at 80% to WOT, for part throttle operation i try to get 13.2 to 13.5
previous AFR was 14.2-14.4 with the generic map for my exhaust & air filter from dynojet, as you can see it is pretty lean.
2003 CBR 600RR JDM
HRC ECU AMA spec
HRC radiator
WP 4618 rear shock
WP 1508 steering damper
Ohlins 9.0N fork springs
Overrev tuned fork cartridges
Akrapovic Evo Carbon FS
Dynojet PCV WB2 POD300
BMC race air filter
AFAM 15/47 sprockets
DID VX2 520 gold chain
Brembo 19RCS MC
HEL brakelines
HM Plus quickshifter
EVR CTS slipper clutch
BST CF wheels
OveRReV is offline
