Is my gas tank okay? - 600RR.net
post #1 of 12 (permalink) Old 12-02-2013, 03:23 AM Thread Starter
So I was wondering if my gas tank piece is rusted or is this normal? The bike has 420 miles but would this be a problem or do I need to replace it @ honda?
Phamous is offline
post #2 of 12 (permalink) Old 12-02-2013, 03:26 AM
eshaw08's Avatar
Not normal what kind of gas are u using. And do u leave it in the rain and its getting water in the fuel tank.
2012 Honda CBR600RR
eshaw08 is offline
post #3 of 12 (permalink) Old 12-02-2013, 03:30 AM Thread Starter
I just purchased the bike a week ago, it's an 08' but been non-op since 11'. What should I do? I just pumped 91 octane almost a week ago and the owner kept it garaged. I don't have any problems riding the bike around the neighborhood.
Phamous is offline
post #4 of 12 (permalink) Old 12-02-2013, 08:00 AM
I would clean that out before it causes any issues. Better to maintain it than wait and see what happens with it.
Sent from Motorcycle.com App
Speedydave is offline
post #5 of 12 (permalink) Old 12-02-2013, 08:46 AM
BOTM Winner 05/15
cbr6racr's Avatar
Feedback Score: 28 reviews
Take the tank off, and drain it. You don't want to fire the bike up with a crap filled tank. Take the fuel pump out, clean the strainer, as that may be clogged.
Once off, get a gallon of CLR, and some stainless nuts and bolts. Pour a good amount of CLR into the tank, with the bolts. Shake the tank around, using the bolts to knock any loose rust of. Let it sit for a while. Pour everything out once you think it's clean. Pressure wash the inside, and let it dry. Once completely dry, grab some Por-15 or equivalent gas tank liner, and apply per directions.
If the top of the tank is like that, the rest of the tank is likely to need some attention.
-Chad
"Logically, any motorcyclist can do 60* of lean. The trick is coming back up again." - Neal Spalding
cbr6racr is offline
post #6 of 12 (permalink) Old 12-02-2013, 11:32 AM Thread Starter
Okay thanks guys appreciate it!
Phamous is offline
post #7 of 12 (permalink) Old 12-02-2013, 11:52 PM Thread Starter
I checked the inside of the tank and it's also semi rusted but I plan to use evapo-rust since it doesn't require any seal or any other products!? What do u think about that?
Phamous is offline
post #8 of 12 (permalink) Old 12-04-2013, 08:25 AM
Miweber929's Avatar
Gas tank is the same from 07-12, there are a thousand bikes being parted every day, get a used tank that's clean and don't screw around with this one. Good thing is since it's under a cover it can even be slightly dented and still be good.
Far cheaper, far easier and a better solution than screwing around with liners.
Mike
Miweber929 is offline
post #9 of 12 (permalink) Old 12-09-2013, 08:08 PM
i wouldnt start the bike like that. and once you get your tank replaced or seriously cleaned, and your fuel pump sorted out, change out the fuel filter then clean your lines and injectors.
EaZ8 is offline
post #10 of 12 (permalink) Old 12-09-2013, 08:36 PM
BOTM Winner 03/14
D1stylz's Avatar
Honestly I wouldn't waste my money, most of them products are not great. Id invest in a new tank be done with it. Atleast you'll know what you have and it'll be garaunteed problem free. Just my two cents
My simple build.
RIP SpdyG_AK 22 June 2014
D1stylz is offline
post #11 of 12 (permalink) Old 12-09-2013, 10:30 PM
kenoman's Avatar
I would replace the tank & all fluids. These bikes are precision machines and need to be maintained. Better to do it now before it becomes a potential problem in the future.
kenoman is offline
post #12 of 12 (permalink) Old 12-10-2013, 07:30 AM
Nico's Avatar
Pull the pump out and seal the bottom with a plate then thoroughly degrease the tank with some simple green or the like then rinse and fill the tank right to the top with a 10:1 mix of water to feed molasses. Leave for 1-2 weeks and then clean it out with water and re-assemble.
Nico is offline
