Arrow exhaust owners, help! - 600RR.net
post #1 of 36 (permalink) Old 05-28-2014, 10:57 AM Thread Starter
PdubRR's Avatar
I just got an Arrow Indy Race slip on for my '12 RR & the mid-pipe has major issues. Basically with everything mounted up correctly the bend of the mid-pipe before it enters the can is firmly pressed against the plastic battery tray. Pic of the problem:
With everything loosely mounted I can slip it all around until there is a proper routing of the mid pipe but then it is not firmly seated all the way into the can inlet. It's actually almost falling out. I thought it might have been a wrong or problem mid pipe but my vendor got Arrow to send me another one & it's just the same. Here's a couple videos showing the problem in detail. Anyone here encounter this?
http://s648.photobucket.com/user/gra...40f14.mp4.html
http://s648.photobucket.com/user/gra...d32fa.mp4.html
PdubRR is offline
post #2 of 36 (permalink) Old 05-28-2014, 02:02 PM
gioarge's Avatar
I didn't forget... I am still waiting from Arrow the new clamp, I emailed them as no news for two weeks and customer service answered me saying they had some problems and they will ship by this week.
Next week I think I will call. As you know I found same your issue in video2, but the one of video1 is not on my pipe (but I have a 2013 so maybe something has been changed).
--- 2013 CBR600RR ---
My Build Thread
gioarge is offline
The Following User Says Thank You to gioarge For This Useful Post:
PdubRR (05-30-2014)
post #3 of 36 (permalink) Old 05-29-2014, 09:44 AM
WRXSTi0487's Avatar
Mine was touching when I first installed it, actually started melting my battery tray without me realizing it at first.
I was able to loosen everything up and rotate it to get about 1/8" clearance and I added some heat shielding in there (along with putting the stock heat shield back after trimming it)
2012 CBR600RR Black - Tripage IT STD, Black Powder Coated Subframe, Rear Pegs, and Rearset with LED turn signals in pegs and LED brake lights in the subframe all modded by Tripage, Proton Flushmounts, ZG Double Bubble Windscreen, Arrow Titanium with Carbon Tip - Modified by Tripage, Tripage Dual Headlight MOD.
WRXSTi0487 is offline
The Following User Says Thank You to WRXSTi0487 For This Useful Post:
PdubRR (05-30-2014)
post #4 of 36 (permalink) Old 05-29-2014, 09:21 PM
with full Arrow system on my 09 it was about 1/2+"from battery tray - I had to loosen midpipe and pull it back and a little rotating of the midpipe /can to get that clearance. can sits straight and centered.
I put some heat shield stuff on Batt tray, and no problem for 30+k miles.
tary preisser is offline
The Following User Says Thank You to tary preisser For This Useful Post:
PdubRR (05-30-2014)
post #5 of 36 (permalink) Old 05-30-2014, 04:17 PM Thread Starter
PdubRR's Avatar
Thanks guys for your input. Shame it doesn't route better. The Yoshimura RS-5 that was on there before fit together and was spaced perfectly.
I'll try playing with it one more time. but as you can see from the video there's no way to have
a) can centered in it's bracket.
b) mid pipe fully inserted into can.
c) space between midpipe & battery tray.
I can have out of three but not all three.
April's BOTM winner has the same exhaust but his looks much much better.
PdubRR is offline
post #6 of 36 (permalink) Old 05-31-2014, 12:59 AM
bend your midpipe to cat join a bit, and it will move all back to get clearance?
PdubRR (06-02-2014)
post #7 of 36 (permalink) Old 06-02-2014, 03:55 PM Thread Starter
PdubRR's Avatar
What would really work is if the midpipe was about 3/4" longer after the last bend. It would fit perfectly then. Re bending it as as it is would be good too but isn't that what I paid for a slip on for? Not happy with Arrow on this one. I know Arrow makes great products and supports top level racing but the Yoshimura RS-5 for my 600RR is a much better executed effort.
PdubRR is offline
post #8 of 36 (permalink) Old 06-02-2014, 04:27 PM
gioarge's Avatar
I agree! I am still waiting since more than a month for a clamp :(
My Build Thread
gioarge is offline
post #9 of 36 (permalink) Old 06-02-2014, 05:04 PM
WRXSTi0487's Avatar
My clamp for the header to midpipe broke the day I tried to install it (my fault for some reason I thought the clamp worked differently and managed to break the weld off lol)
But yeah I have been in contact a few times to try to get a replacement and a new spring (that got lost when I moved) but yeah have heard nothing.
I saw somewhere they said it must be ordered through one of the vendors but never have had one say they could do it.
It's not ideal but I just clamped it down with a good t-bolt style instead (would work better if it was an expandable style pipe with slits in it)
post #10 of 36 (permalink) Old 06-09-2014, 02:08 PM
gioarge's Avatar
An update: the shop where I bought the Arrow received the new clamp but.... they sent me exactly the one included in the Exhaust kit (about 50 mm of diameter) so useless...
Emailed them again... let's wait! :(
My Build Thread
gioarge is offline
post #11 of 36 (permalink) Old 06-09-2014, 02:19 PM
Ldn
Ldn's Avatar
Thats odd because mine fit without a single problem. It actually fit better than my Akrapovic (marginally).
"I don't want to burden you with my problems... but I think I've outgrown my yacht."
Ldn is offline
post #12 of 36 (permalink) Old 06-09-2014, 03:33 PM Thread Starter
PdubRR's Avatar
I ended up sending it all back. Shame as it's a nice can. I went for it because I like how the end cap tapers down so if you fit a brake light into the tail more of it would be visible. I think I found part of the problem as I was packing it up to ship. Both mid pipes were identical & had the correct part # for my bike. The part # of the can was correct on the box but I noticed the blue tag that was ob the can said it was for the 2007. Anyone think there's a difference between the 2007-08 can & the 2009-2012?
PdubRR is offline
post #13 of 36 (permalink) Old 06-09-2014, 03:40 PM
gioarge's Avatar
I am riding even if the spring is not installed in the right way, but if I spent so many money I need a solution from them.
In my opinion there is something wrong with the 2013 kit.
I do not want to change it because it sounds amazing and also I really like it.
I hope to have good news soon
My Build Thread
gioarge is offline
post #14 of 36 (permalink) Old 06-09-2014, 08:25 PM
mran556's Avatar
off topic but where did you get the exhaust from and how much?
Feel free to pm me
2007 Cbr600rr Black
mran556 is offline
post #15 of 36 (permalink) Old 06-10-2014, 06:23 AM
gioarge's Avatar
Feel free to pm me
if you are asking me I got it from a local vendor (I checked but they do not export, sorry) for about 500 (pipe and link pipe).
My Build Thread
gioarge is offline
post #16 of 36 (permalink) Old 06-10-2014, 04:36 PM
WRXSTi0487's Avatar
Is the clamp you got the one that holds the midpipe to the header via spring?
If so and you don't need it could I get that from you? lol
post #17 of 36 (permalink) Old 06-10-2014, 04:57 PM
gioarge's Avatar
yes it is that one, let's see if they want it back via dealer; if not, for sure I can send it to you but I think it will cost more the shipment than getting it brand new form a local dealer
My Build Thread
gioarge is offline
post #18 of 36 (permalink) Old 06-10-2014, 05:02 PM
WRXSTi0487's Avatar
I've tried asking a couple of Arrow dealers about it but none of them would ever write me back about it. So I basically gave up and kept my bo-bo method for the time being lol.
(a cheap bubble wrap envelope 1st class USPS wouldn't cost much I imagine)
post #19 of 36 (permalink) Old 06-10-2014, 05:06 PM
gioarge's Avatar
Okay man. Really no problem if they leave it to me. Tomorrow I will check the postal office website for a quote from Italy to USA, sorry but never sent something.
My Build Thread
gioarge is offline
post #20 of 36 (permalink) Old 06-10-2014, 05:26 PM
WRXSTi0487's Avatar
Ahhh I didn't even notice you were in Italy at first, worth a quote at least if they don't want it.
I'll message you some info for a more accurate quote.
post #21 of 36 (permalink) Old 06-12-2014, 03:53 PM
gioarge's Avatar
No problem man :) still no news... I will write/call next week if still no news...
My Build Thread
gioarge is offline
post #22 of 36 (permalink) Old 06-12-2014, 04:22 PM
WRXSTi0487's Avatar
I am currently waiting to hear back from a Vendor myself who sent an email to Arrow about it, I looked through your build thread and see you broke the clamp the same as I did, over-tightening it. I never really even got it in the right position to try apparently.
post #23 of 36 (permalink) Old 06-12-2014, 10:01 PM
Had the same problem with mine on my race bike.
https://www.600rr.net/vb/showthread.php?t=388289
I removed the battery box and modified it also. Removed the exhaust valve and plated up the hole with thin stainless plate and then went around the base of the battery box with heat tape etc.
I think it is because it is a race track focused pipe they assume you will be running a racing subframe/battery box etc.
TBH, I dynoed it and found the Akra put out more ponies so I am now running that.
you can kind of see it in the first image here:
Check out my racing/bike build page on bookface: www.facebook.com/JeremyHolmesRacing
Maido is offline
post #24 of 36 (permalink) Old 06-13-2014, 07:22 AM
Rad Rage's Avatar
That is a great looking bike. But I believe the system you are running is different from OP's. Yours is the full competition system right?
2011 CBR600RR 'X-Ray' Build Thread
https://www.600rr.net/vb/showthread.php?t=294795
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
post #25 of 36 (permalink) Old 06-17-2014, 04:00 PM
gioarge's Avatar
Today I sent them a new email asking for some news as after 10 days no news... Really strange.
I called the shop where I buy almost all the goodies and they said me that also Arrow does not have a good financial situation. I hope they are wrong as we lost leovinci since a while...
Let's wait some days more then maybe I can try to call them.
More updates as soon as I have.
My Build Thread
gioarge is offline
post #26 of 36 (permalink) Old 06-18-2014, 12:35 AM Thread Starter
PdubRR's Avatar
That's bad news. I hope it's not what's happening. That would explain the the bad info they gave about the mid pipe clamp. Maybe they're also having trouble with QC due to financial problems. Always loved Arrow & had them on my NSR250 back in the day.
Leo Vince is gone?
PdubRR is offline
post #27 of 36 (permalink) Old 06-18-2014, 01:51 AM
gioarge's Avatar
Leo Vince is gone?
As far as I know (newspapers) yes... :( many people as been fired and I also read something here on the forum of a vendor encouraging to buy the stock as it should be the last one...
My Build Thread
gioarge is offline
post #28 of 36 (permalink) Old 06-18-2014, 01:00 PM
WRXSTi0487's Avatar
I know I spoke with a vendor again about the clamp and apparently the contact at Arrow has been out of vacation for a bit so maybe that's why you haven't heard back either.
post #29 of 36 (permalink) Old 06-18-2014, 02:40 PM
gioarge's Avatar
Just got an answer today after my reminder... He asked me to recap all the history with pictures and part number too... Just sent the whole history. Let's wait again.
Maybe yes regarding the out of office, but it happened to me other times during these months....
At the end I still do not have a solution :(
My Build Thread
gioarge is offline
post #30 of 36 (permalink) Old 06-23-2014, 05:26 PM
gioarge's Avatar
New updates.
I exchanged some emails again but with a new person from their technical support.
He said me to place the clamp exactly where I installed the first time and so I pointed out that then the spring is not at the right tightness. He asked me to send them the exact dimension of OEM headers to make a new clamp but I questioned again about the spring... So ping pong of emails and I asked for a telephone number in order to call...
Now they are answering but after months still no solution, I just really like the look and the sound otherwise I would change it.
Other news as soon as I will have other updates.
My Build Thread
gioarge is offline
