UK/EU/USA riders please help me understand O2 - 600RR.net
post #1 of 5 (permalink) Old 08-18-2014, 01:18 AM Thread Starter
Sensors .....07+ CBR's in EU/UK have them?
A respected friend says bikes on EU/UK specs have 02 sensors.
but they only have an emission control function.......so they do not have a real control loop to the ecu (not like OBD 2 ecu's on autos).
Where would they connect to the ecu, Are EU/UK ecu's different?
US spec bikes do not?
My 09 (cali spec does not have an O2 sensor).
AFIK no USA spec bikes come with them...........?.
Last edited by tary preisser; 08-18-2014 at 01:27 AM. Reason: beer fueled - ask a dumb ?
tary preisser is offline
post #2 of 5 (permalink) Old 08-18-2014, 03:01 AM
Rad Rage's Avatar
The only thing I know is that the EU (which includes UK) and US ECUs are different. By testament of HMRacing which have informed me that there are enough differences to prevent their dashes from working with US ECUs. Secondly, EU bikes do not require Dynojet's IRC/Bazzaz's Z-Bomb, installing them would mess the bike up because they are not subject to the stock ignition retard at 100% throttle like the US ECUs.
Euro bikes have O2 sensors which are visible if you look from the right side of the bike at the header extension right below the rearsets, it is used to keep emissions in check. Don't know about the US bikes regarding this point.
2011 CBR600RR 'X-Ray' Build Thread
https://www.600rr.net/vb/showthread.php?t=294795
Co-President of Team46
"My bike is too fast for the track" Ubercool ZX-14R rider.
Rad Rage is offline
The Following User Says Thank You to Rad Rage For This Useful Post:
tary preisser (08-18-2014)
post #3 of 5 (permalink) Old 08-19-2014, 11:50 PM Thread Starter
What purpose does the 02 sensor serve?
is it just an (limit value exceeded) idiot light?
does it modify fueling/ignition at all?
post #4 of 5 (permalink) Old 08-20-2014, 02:30 AM
Rad Rage's Avatar
My guess is the O2 sensor basically reads the oxygen levels from the exhaust streams and sends these readings to the ECU which can then compensate by adjusting the air to fuel ratio so that it stays within the programmed limits, complying with whatever level emmission laws constitute as acceptable.
Rad Rage is offline
post #5 of 5 (permalink) Old 08-20-2014, 02:43 AM
My understanding with o2 sensors on bikes is that the bike will only run in open loop to trim the fuel tables within the emissions standards testing zones. Basically they will lean the mixture in the bottom end. I'm not sure if there are any bikes out there that run a true open loop. Its basically a band aid to pass emissions.
Sometimes bikes fitted with factory o2s will have a hitch in the fuelling when the bike crosses over from a modified open loop back to closed loop. This is easily defeated with an o2 emulator.
wibbly is offline
tary preisser (08-20-2014)
